It is currently Wed Oct 14, 2026 3:30 pm
PostPosted: Wed Jan 18, 2012 3:29 pm
It is the mounting plate I'm questioning.
One end bolts to distributor body, the other end bolts to engine.
Is there a starting point for setting the distributor bolt ?
As in the middle of the slot arc ? Where do I start ?
Which one is used for final timing light adjustment ?
Help.
"Hewy"
PostPosted: Wed Jan 18, 2012 5:22 pm
tighten one under dist in the middle....bring engine to TDC on #1 ...install dist so rotor end up pointing at #1 on cap....use base bolt to adjust timing ....if a bit more is needed use bolt under dist .... if not enough remove and move a tooth....if done right both bolts should be near center of slot
PostPosted: Wed Jan 18, 2012 5:48 pm
<CORRECT>!
PostPosted: Wed Jan 18, 2012 6:25 pm
Simple enough, I can handle that.
Thanks very much 8)
"Hewy"
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot], Google [Bot] and 11 guests
