It is currently Mon Nov 30, 2026 2:06 am
 Post subject: Hydraulic Clutch?
PostPosted: Thu Jan 19, 2012 7:18 pm
Hi All,
Have any of you used a hydraulic clutch set up with your A833? I'm installing an OD A833 in the 62 Toad and am looking for the "best" clutch setup.
John
1962 Plymouth Valiant
PostPosted: Thu Jan 26, 2012 4:01 am
I did a 833od conversion on my 65 Dart & at the same time installed a hydraulic clutch. I'd expect a 62 install to be similiar.
I considered the final product very successful & put together 47 pictures of the hydraulic clutch install using external cylinder as well as 5 instructional step by step installation sheets & parts & tool lists on the hydraulic clutch installation so that my daughter can do the same to her 65 Dart with 833OD.....she's 3000 miles away so she got a "kit" including tools mailed to her as well as the detailed instructions to compensate for me not being able to assist.
Your welcome to the instructions & pictures if you send me a PM with your email & I'll send them out in multiple emails.
