It is currently Tue Jun 23, 2026 10:22 am
 Post subject: engine block
PostPosted: Fri Jan 27, 2012 5:57 pm
i need to pick up another block, so i can have it machined and swap all my parts over.
is their an easy way to tell from different size slant sixes? i need a 225, for a 65 valiant
PostPosted: Fri Jan 27, 2012 6:00 pm
http://www.slantsix.org/articles/dutra- ... blocks.htm
PostPosted: Sat Jan 28, 2012 11:40 am
Seems to be for racing purposes, would just like to know if my 65 crank will drop into which years? I don't know if its cast or not
PostPosted: Sat Jan 28, 2012 11:58 am
59-74 Forged crank
75-87 Cast crank
 Post subject: Correction
PostPosted: Sat Jan 28, 2012 12:00 pm
59-74 Forged crank
75-87 Cast crank
59-76 Forged crank
76-87+ Cast Crank
PostPosted: Sat Jan 28, 2012 12:43 pm
Is there an obvious difference between the two style blocks? Is there anything else I need to take into consideration for part interchangability? Heads... Motor mounts, uhh pan or pickup? Or is everything else good to go?
Also, would it be okay to reuse the main bearings on a different block? Everything is 100% new, just my current block is bad and everything is torqued down as of now
PostPosted: Sat Jan 28, 2012 1:50 pm
Rob-
Thanks for the correction. I have seen 75's that had cast crank motors,but I guess they were swapped in later.
Kielbasa- Yes you can reuse the bearings if they are new.
 Post subject: Bearings
PostPosted: Sat Jan 28, 2012 1:55 pm
The forged crank uses wider bearings than the cast crank version...
Doc's motor article is a good guide.
PostPosted: Sat Jan 28, 2012 2:10 pm
Is there a part number guide somewhere?
PostPosted: Sat Jan 28, 2012 2:25 pm
http://www.slantsix.org/articles/parts-matrix/jpg.htm
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
