It is currently Sun Jun 21, 2026 2:38 am
 Post subject: Cleaning gunk out.
PostPosted: Sun Jan 29, 2012 5:53 am
After changing old dirty oil and adding a pint of
Marvel Mystery, the first start start up produced
copious amounts of gray colored smoke.
Several starts , same smoke for about 15 to 20 minutes,
and dialing in timing and carb adjust, it settled down to
small amount of more blue smoke. Burning oil right ?
None at idle, only when RPMs increased.
I read here about cleaning "oil bypass valve"
How is that done ?
I'm new to slants :wink:
"Hewy"
PostPosted: Sun Jan 29, 2012 10:07 am
Service the oil pressure relief valve to make sure it's doing its job, as described in these two threads: thread 1, thread 2.
Engine cleanout info here.
You'll want to get the three books described in this thread as quickly as you can.
PostPosted: Sun Jan 29, 2012 12:51 pm
OK I did find some of those posts after I wrote
my question.I know should have done the search
first, but then would not have had your reply. :lol:
That is my next plan to buy a manual specific
to the slant six.
By the way mine is a 1964 D100 pickup with a 225/6
and 3 speed manual trans.
"Hewy"
