It is currently Tue Sep 29, 2026 8:40 pm
 Post subject: aluminum drive shaft?
PostPosted: Sun Jan 29, 2012 2:08 pm
anyone ever run one..?
like?
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Jan 29, 2012 2:18 pm
My 89 Ford van was built with one from the factory. It was very light and did a good job transferring the rotational force form the transmission to the rear axle. I swapped it out for a steel driveshaft due to transmission and rear axle changes, but i will be reinstalling the aluminum driveshaft eventually.
The only real advantage to an aluminum driveshaft is weight savings.
PostPosted: Sun Jan 29, 2012 2:36 pm
any idea about average weight savings..
slant six's RULE!
PostPosted: Sun Jan 29, 2012 6:45 pm
And More power gets to the rear tires with that weight savings.
PostPosted: Sun Jan 29, 2012 6:49 pm
i will be getting An Aluminum or Carbon Fibre Driveshaft when Budget allows.
Better et's
:D
PostPosted: Sun Jan 29, 2012 7:07 pm
I have an aluminum drive shaft.
http://www.dynotecheng.com/
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Jan 29, 2012 7:35 pm
Er-ruh…
…uh…
:shrug:
PostPosted: Sun Jan 29, 2012 7:49 pm
Never had an aluminum driveshaft, but Denny's makes quality products. I had a HD & a stub shaft for my Jeep made by them years ago.
http://www.dennysdriveshaft.com/index.html
1964 Dart GT
PostPosted: Sun Jan 29, 2012 7:55 pm
Have one in my '64 Dart, for last 9-10 yrs, from Denny's. 7-8lbs wt savings, IIRC.
PostPosted: Mon Jan 30, 2012 2:09 pm
My Dart has one, came from the JY. Marked "Ford van", a la Reed.
Tape measure said it was the right length, used a hybrid u-joint to match it to the yokes, and away we go.
I didn't weigh it, though.
But I can feel all that extra power!!!! :lol:
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
