It is currently Tue May 19, 2026 5:57 pm
 Post subject: 5/16" tubing beader...
PostPosted: Mon Jan 30, 2012 7:56 pm
Anyone have a good recommendation on an inexpensive tubing beader for 5/16" metal fuel line? I can find one for 3/8", but the internet search shows that one for 5/16" is $129.... :shock:
Thanks for the recommendation,
PostPosted: Mon Jan 30, 2012 8:09 pm
I have one similar to this which I like.
http://www.sourcingmap.com/calibrated-h ... =usfroogle
PostPosted: Mon Jan 30, 2012 8:40 pm
Inexpensive, don't know about good.....
http://www.harborfreight.com/tubing-bender-3755.html
 Post subject: Lol...
PostPosted: Mon Jan 30, 2012 9:10 pm
:lol:
Tubing Bender I got...tubing beader is what I need... it's a tool that adds a 'bump'/ridge/bead/'barb' to the metal fuel line so it doesn't slip off if using a hose clamp...
:lol:
I know that Earl's makes one for most V-8 sized lines...
http://www.summitracing.com/parts/EAR-008ERL/
but am looking for one for slant six sized fuel lines....
Thanks,
PostPosted: Mon Jan 30, 2012 9:13 pm
:oops:
Got a double flare tool?
If you don't complete the double flare, you have a nice bump on the end so the hose doesn't slip off........
PostPosted: Mon Jan 30, 2012 9:16 pm
6 Pack Dart
Rob use a flairing tool gently a small ridge can be put on tubing.
Richard
 Post subject: Good Idea.
PostPosted: Mon Jan 30, 2012 9:24 pm
Sounds like I will need to find a quality tool. This is one item I do not have. (Have not needed until now...LOL).
Thanks guys!!!!
PostPosted: Mon Jan 30, 2012 9:57 pm
Oops! So much for reading comprehension!
I use my double flare tool to bead fuel lines.
PostPosted: Tue Jan 31, 2012 2:07 pm
timly post as tubeing benders and flair tools was what I was just starting to look for.
for the benders shown,, will they pull compact enough bends to re produce the short fuel line shown?
http://www.flickr.com/photos/13718356@N ... 120223267/
for the beaders mentioned,, any brands / styles that are recommended?
I am looking for ones that will do the ends on the fuel lines..
thanks
PostPosted: Tue Jan 31, 2012 2:38 pm
John for a bend that tight you are better off with the spring types that fit over the line. A bend that short will usually collapse where it is held by the bender.
PostPosted: Tue Jan 31, 2012 3:03 pm
I got a few spring style benders with the tools in my dad's estate years ago,, but I never used them, I'll look around and dig them out.
 Post subject: swagelock
PostPosted: Tue Jan 31, 2012 3:10 pm
Swagelock makes some premium benders(Not cheap) that I use at work for bending 3/8 SS tubing. They work great and don't kink even with hard SS tubing. The problem with getting that short of a tube is that the nut usually gets in the way of the shoe as it comes around.
Rick
PostPosted: Tue Jan 31, 2012 8:07 pm
I've used benders like the ones linked to earlier in this thread to put a bend close to the end like the picture. What I do is put the nut end under the hook and bend away from it. Or you could do the bend then do the flair.
Nuttyprof
Dave
1972 d-100 parts truck
PostPosted: Tue Jan 31, 2012 8:48 pm
there are also some plier type benders, they will let really tights bends and dont let the nut get in the way. Lisle makes some
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
