It is currently Mon Jun 01, 2026 12:17 am
PostPosted: Fri Jan 27, 2012 8:31 pm
i am in some need of some tires for my 65 valiant. stock bias ply was 6.50x13 which basically comes out to 175/80/13. now the only tires i can find seem to be "trailer tires" is there anyone who actually makes a real 13 inch tire for our cars, that will hold up like any normal tire would? especially for our cars which are on the heavier end for 13's now days
PostPosted: Fri Jan 27, 2012 8:38 pm
You're better off getting some 14" rims with
185 75 (4.5" rim width)
195 70 or 205 70 (5.5" rim width)
PostPosted: Fri Jan 27, 2012 8:42 pm
Firestone sells the FR380 in 175/80/13.
I have these on my 63 Dart GT hardtop.
Nice tire.
--Walt Jackson
PostPosted: Sat Jan 28, 2012 4:31 am
14's are a good upgrade for our old A bodies. Your mileage may even go up a bit!
PostPosted: Sat Jan 28, 2012 6:01 am
Contributor
The last 13s I found were Hankook. My local Discount Tire got them for me overnight.
PostPosted: Sat Jan 28, 2012 8:07 am
I see no reason why milage would go up with 14s. A different tire then stock would mess with your mph reading, and could either make your mpg look better, or worse.
PostPosted: Sat Jan 28, 2012 8:54 am
Going with 14" wheels gives you a Greater Selection of tires!, and depending on the wheels you choose, a greater selection of brake upgrades. MPG? I don't know about that? MPH. Yes it does effect it slightly, but if you're rollin' on 13" bias-ply, you got other problems than speeding. :shock:
1964 Dart GT
PostPosted: Sat Jan 28, 2012 12:25 pm
A larger diameter tire should mean that the axle will have to rotate slightly slower at any given speed the car is traveling.
Slower axle rotation means reduced engine RPMs.
Reduced engine RPMs should result in better MPGs.
Yes?
- Mac
PostPosted: Sat Jan 28, 2012 12:35 pm
Going to a larger rim doesn't necessarily mean any change in axle RPM or overall MPG. The critical factor is overall tire diameter. 13 and 14 inch tires can have the same overall diameter, but the 14 inch tire will have a shorter sidewall. A short sidewall will give better handling, but unless you go to a 14 inch tire that has an overall larger diameter, a 14 tire will not necessarily mean better MPG or a different axle speed.
I would change to a 14 inch rim for greater choice of tires as well as rims.
PostPosted: Sat Jan 28, 2012 12:55 pm
I prefer the stock rim with dog dishes, I like the look a lot, with s semi gloss wheel, and a very narrow white wall.
As for tires choices it seems the firestones are a good way to go, there is also a kumho solus, and cooper trendsetter that was suggested in forabodies.
It's a complete stock car, no need for special brakes, or superbeetle handling. Just a old cruising hunk of steel, which taller side walls equal softer ride
PostPosted: Sat Jan 28, 2012 2:52 pm
The 13" dog dish hubcaps fit the 14" rims just fine.......
13 vs 14 (6.50 vs 195/70)
PostPosted: Wed Feb 01, 2012 6:26 pm
I tried getting a set of these a year and a half ago and was told they were discontinued. Its getting hard (and expensive) to ride on 13s, I'd suggest upgrading to 14s as well.
'66 Dodge Dart
