It is currently Fri Oct 09, 2026 7:08 pm
PostPosted: Thu Feb 02, 2012 11:12 pm
Car Model: 1963 Dodge Dart convertible
Hi Guys. I have a 63 dart with 125k on the engine and it is leaking some oil when sitting in my garage. Should I just replace the seal when I pull the oil pump or should I replace the pump with a new one since its out?
Thanks
John
Psychics will soon lead dogs to your body!
1963 Dodge Dart 270 convertible
PostPosted: Fri Feb 03, 2012 6:53 am
did you try retorqueing the bolts????
PostPosted: Fri Feb 03, 2012 7:36 am
Which gasket is it leaking from, the block or the pump?
PostPosted: Fri Feb 03, 2012 8:52 am
I have not tried to retighten the bolts yet still in exploratory mode and I am not sure if it is the pump or the seal. I figured once I lifted things up and got access to the pump I could check it all out, I already have the pump to engine gasket and thought I would replace it since it I access.
Sounds like I should do some more digging first?
Thanks for the quick responses.
We have a beautiful sunny warm day here is Seattle its almost 50°!
PostPosted: Fri Feb 03, 2012 10:25 am
6 Pack Dart
First clean the area and the pump (external) then drive or run engine to see where the oil is really coming from. Might just be a leaky sender unit.
Richard
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 21 guests
