It is currently Sat Oct 10, 2026 9:45 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Mon Feb 06, 2012 2:26 pm
That was a close call :shock: . Thats alright Reed. Thank you Charrlie. i should of checked the order of the bearings twice :oops:
so hydraulic bearings would not work because it is originally a solid lifter block?
Is there a down side if the cam does not have a groove?
PostPosted: Mon Feb 06, 2012 2:50 pm
Buy the bearings to match the block.
If the cam does not have a groove, then it isn't a factory hydraulic slant six cam. I don't know if aftermarket supplies use cam blanks with grooves to make the hydraulic cams. For instructions on how to change a mechanical cam motor to a hydraulic cam, see HERE.
PostPosted: Mon Feb 06, 2012 6:21 pm
As far as I know there was never a grooved rear cam bearing. The groove was on the cam.
It is the front bearing that has the groove.
When I built my first good motor it was generally accepted Internet lore that the factory bearings had a groove in the rear bearing. I could never find grooved bearings.
I believe that can now be laid to rest.
The MP cam I got from Mike last weekend is grooved.
I had a Lunati hydraulic. I can't remeber if it was grooved or not.
Getting old is not for the timid. :shock:
PostPosted: Mon Feb 06, 2012 6:54 pm
i just tore apart which i believe is a competley untuched motor. it has std/std factory bearings, factory stock pistons, still had rope seal, blah blah
and none of the cam bearings had a grove, and the rear one had 2 holes.
 Post subject: Yes...
PostPosted: Mon Feb 06, 2012 7:00 pm
I know the blanks OCG has are that way, and since they are low on original mech blanks with good fuel pump lobes, they will make a deal
on a new hydraulic blank if you order a mech camshaft, but ask for the
groove...(I did this on my last order since I am never sure if the new blanks are drilled correctly or not for the oil feed...)
PostPosted: Tue Feb 07, 2012 2:33 am
I put a small groove on all my cams. If I wind up with excessive oil to the top end, I can always install a restrictor in the oil passage in the rear rocker stand, without taking everything apart.
Users browsing this forum: Amazon [Bot], Google [Bot] and 17 guests
