It is currently Mon Oct 12, 2026 3:11 am
PostPosted: Mon Feb 06, 2012 7:00 pm
i just picked up a virgin engine, complete, for 100 bucks, i just tore it down, its still std/std/std on everything, its the correct era block, i almost feel bad cutting it to .060, but it needs to be done.
the one thing i forgot to do, is check the deck height on front of block, to rear. to see if there was any slant in the deck.. ohwell, highly doubt it, and if any, prob not worth getting done. if the deck is flat anyway.
how often do blocks need to be decked?, whats the average cost of bore/hone from std to 60., any other things should be looked into or ask builder to check out. if im doing this twice, might aswell put twice the effort into making sure everything is as good as can be.
again, this is for a stock motor. nothing fancy other then a slightly different cam, and a hardened oil pump gear
PostPosted: Mon Feb 06, 2012 8:04 pm
6 Pack Dart
If it were me, I would bore it 0.030 that way you could re-bore bigger on the next re-build.
Richard
PostPosted: Tue Feb 07, 2012 11:12 am
do you have money for a new set of pistons, including pressing them on and off? i dont plan to rebuild this motor for a long long time. unless someone wants to trade me brand new 30's for my 60's
PostPosted: Tue Feb 07, 2012 11:40 am
You can certainly rebore for 0.100" later, so don't worry about going 0.060".
Users browsing this forum: Google [Bot] and 28 guests
