It is currently Thu Nov 12, 2026 3:33 am
PostPosted: Tue Feb 07, 2012 11:00 am
I'm preparing a new head and would like to have my calculations checked before I have the shop remove material.
- The engine is a 225 overbored .040" to 3.440"
- Stock rods, assume length of 6.699"
- Measured deck heights of #1 and #6 cylinders. -0.186" and -0.185" respectively, +/- .001
- Installed exhaust seats and did valve job, then measured chamber volume of #1 = 58cc; volume of #6 = 56cc
- I have a stock replacement TRW cam. I don't know the exact specs of the cam (lost records), but I am going to assume Intake ABC closing of 50 deg.
- I measured the used, compressed Felpro head gasket. It is .040" thick.
I calculate that installing the head as is, and using 56cc and -0.185" deck, to be conservative (conservative meaning I don't want knock), the static C.R. is 7.96. Using the rb racing online calculator, I get a dynamic of 7.04 at SL.
If I go for 9.0 static, dynamic of 7.94, I calculate a chamber volume of 44.3cc.
To reduce from 56cc to 44cc I would need to remove 0.076" from the head.
This is definitely a time when I want to measure twice and cut once, so please let me know if my math is wrong.
Thanks,
Robert
Robert Troy
69 slant 6 OD4 Barracuda conv
68 383-S 4 speed convertible
PostPosted: Tue Feb 07, 2012 12:07 pm
6 Pack Dart
Other than the cam, mine in the Dart has the same dimentions, and I had 0.100 off the head and it gave me a 42cc chamber with 9.1 static compression.
I run "cat pee" regular and have no pinging.
Richard
PostPosted: Tue Feb 07, 2012 12:13 pm
...but I am going to assume Intake ABC closing of 50 deg...
Stock cams usually have a IC in the 30 - 45 degree range...
To do the job right, mock-up the cam and find the true Intake Closing point.
PostPosted: Tue Feb 07, 2012 12:39 pm
Agreed. This isn't the time for guesswork.
PostPosted: Tue Feb 07, 2012 1:04 pm
OK, didn't expect that.
I should be able to do it if I pull the radiator and attach the degree wheel.
Thanks,
Bob
Robert Troy
PostPosted: Tue Feb 07, 2012 2:52 pm
Yes... you really need to know the IC point, to get an accurate DCR number.
Example, I entered all your info. (58 cc head), including the 50 degree IC point, into the KB calculator and got a 7.795 static CR and 6.892 DCR
Changed the 50 degree IC point to 30 degrees and get a 7.472 DCR.
The intake valve closing point has a big effect on the DCR number.
PostPosted: Tue Feb 07, 2012 5:19 pm
This will make you rethink cam choices.
PostPosted: Wed Feb 08, 2012 11:53 pm
I took mine down .115 to get to a static 10.5:1, which got me down to, if I remember right, a 42cc chamber.
I probably should have kept going and upped it to 11 or 12, but i got tired of the bill rising.
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Sun Mar 18, 2012 2:31 pm
I'm assuming that with all this upping the compression you are using a high Octane fuel to match? about to clean up the head on our replacement motor was going to take 0.070" just to get back to clean metal this is only a part time motor so I can rework the original motor with the works, but what is the optimium amount to shave off a head to run on 95-97 octane fuels? RAY
PostPosted: Sun Mar 18, 2012 5:10 pm
Site Admin
What is your chamber volume, deck, overbore, crushed gasket thickness, Fire ring diameter, cam selection and stroke Ray?
The question can't be answered without the above parameters.
CJ
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot], mr.norm and 3 guests
