It is currently Tue Oct 13, 2026 6:29 am
 Post subject: 170/225 cam interchange?
PostPosted: Mon Feb 06, 2012 11:59 am
Thanks for the input on my cam selection.
I brought the cam from my 62 225 to OCG and they told me it was a 170 and the con rods would hit it if installed in a 225.
The cam is out of my 225 and it appears that is is original. Did the early motors use different rods, is this a fluke or something else?
OCG can notch it for clearance, but if it is not necessary I will tell them not to.
Should I notch, find a different core or have them grind it as it is?
Thanks again!
These ones go to eleven...
PostPosted: Mon Feb 06, 2012 12:22 pm
Sounds like you have one of the thicker shaft cams.
No worry, the con rods will not hit it... grind away.
PostPosted: Wed Feb 08, 2012 5:17 pm
Thanks Doc!
I called OCG this morning and pulled the trigger...
PostPosted: Wed Feb 08, 2012 8:27 pm
Are all early cam the thicker shaft? Why the difference, application? Ken at OCG thought they were 170 only and said that most of his /6 cam cores are this style.
Curious?
Cheers!
PostPosted: Thu Feb 09, 2012 6:15 am
I have seen many thick 225 cams on the earlier ('63-down?) motors, so I think it was both engines, just an earlier year thing.
PostPosted: Thu Feb 09, 2012 8:00 am
Thanks Lou,
I'll pass that on.
