It is currently Sat May 16, 2026 3:16 pm
Post new topic  Reply to topic  [ 382 posts ]  Go to page Previous 17 8 9 10 1126 Next
PostPosted: Wed Feb 08, 2012 9:32 am
I recommend that we shift ALL discussion of this topic to the "Rule changes..." post in the main part of this Racing section. There are a lot of double posts and things are getting confusing.
This sticky post about records is supposed to be for posting of records, and direct discussion of actual records.
If I am wrong in my thinking, please advise (esp moderators).
Since I was the one that set the original weight breaks I will tell you how it was done. First the breaks were set to fit the serious slant 6 race cars that were around at that time. A fairly seriously lightened A Body like the Cox Bros, Goodman's, Guzzi's, or my blue Valiant come in at about 2350, A more typical racing A body like Merils, Rodneys, Ron Hambys. Barry Harrisons, Howard Davis', or Mike Jeffrey's are closer to the 2700#. The minimum for A class was set at 2000 because that is the minimum for an NHRA super street car where I hoped more of us would be competing. As far as I know only Dale Rose's car got to 2000 most other A cars are in between but a 2000# doorslammer is certainly possible. I also set the weight breaks with the idea of making the low deck engine competitive at the weight break for the next fastest class. i.e. you could go for the B class record while weighing 2000#. Nobody ever made a serious attempt to take advantage of this but that is also a reason the breaks are 350# apart.
When the D class was added I think the idea was to accomdate later model street cars that come in about that weight. There is no real reason the classes have to be the same distance apart.
If you were going to start with a clean sheet of paper you should probably define the classes on a weight per cubic inch basis like most NHRA classes. Originally the whole national record system was set up to give some recognition to racers who built there cars to go fast and to increase participation. Many racers have traveled to a slant 6 race just to try to set a record. Instead of changing everything around so you can get an easy record why don't you figure out how to set one under the existing system? The current system can accomodate practically anyone, you can always add weight to run in a heavier class like Mark did.
PostPosted: Wed Feb 08, 2012 4:06 pm
I thought I posted this in the rules change thread. Musta been sniffin' glue again.
If anyone is technologolically advanced enough please split it into the other thread. :lol:
PostPosted: Thu Feb 09, 2012 10:50 am
On the topic of records, how about listing the body style and the location where the record was set like they do in the NHRA?
61-62 Lancers rule!!
Mark
And I'd also like to see the weight of the car as it ran for the record. Just as a reference. No dog either.
Rick
I like these ideas too! :D
When I look through records or who the leaders are in whatever type of racing I always look for the type of car they are running.
For people looking in that aren't already familiar with the main players here I think this would add something.
Just seeing "your car" listed as having a record makes you more interested in it. :wink:
PostPosted: Thu Feb 09, 2012 12:37 pm
Hey Ryan,
Since a couple people have asked, I went through and added the vehicle types and most locations. Some of the locations I couldn't narrow down exactly because my spreadsheet didn't have all of the dates. I'll go through my SSRNs to add the right locations. No idea of any claimed weights. I assume Seymour has the claimed weights for everyone (?)
Any mistakes or if you know the location for any records, please post here. Thanks! :D
Here are the updated records as of 9/20/11
Also note the added AA Class for any Slant 6 powered vehicle under 2000 lbs.
All records in red are new for 2011
Weight of less than 2000#
Class .......Date.............Driver...................Record..........ET/MPH………….Car……………………Location……………….Weight
Gas Only
AA/G.........................Open Record.............1/4 Mile ET...............
AA/G.........................Open Record.............1/4 MPH...................
AA/G.........................Open Record.............1/8 Mile ET...............
AA/G.........................Open Record.............1/8 MPH...................
Alcohol
AA/A.........................Open Record.............1/4 Mile ET...............
AA/A.........................Open Record.............1/4 MPH...................
AA/A.........................Open Record.............1/8 Mile ET...............
AA/A.........................Open Record.............1/8 MPH...................
Nitrous
AA/N.........................Open Record.............1/4 Mile ET...............
AA/N.........................Open Record.............1/4 MPH...................
AA/N.........................Open Record.............1/8 Mile ET...............
AA/N.........................Open Record.............1/8 MPH...................
Unlimited
AA/S.........................Open Record.............1/4 Mile ET...............
AA/S.........................Open Record.............1/4 MPH...................
AA/S.........................Open Record.............1/8 Mile ET...............
AA/S.........................Open Record.............1/8 MPH...................
Weight of 2000-2349#
Class .......Date.............Driver...................Record..........ET/MPH..........Car……………………Location……………….Weight
Gas Only
A/G......7/16/11.....Mark Etheridge............1/4 Mile ET.....11.436………….’62 Valiant…………Eureka, CA…………….XXXX#
A/G......7/16/11.....Mark Etheridge............1/4 MPH.........115.51MPH…..’62 Valiant………..Eureka, CA……………XXXX#
A/G......10/14/06...Seymour Pederson.......1/8 Mile ET......7.250…………..’62 Valiant…………Piedmont, NC..…XXXX#
A/G......5/8/04.......Dale Rose....................1/8 MPH.........92.632MPH….’?? Arrow…………..Farmington, NC……XXXX#
Alcohol Only
A/A......5/22/11......Will Burns...................1/4 Mile ET.....11.441…………’67 Barracuda……Hagerstown, MD…..2190#
A/A......5/22/11......Will Burns...................1/4 MPH.........117.92MPH….’67 Barracuda…..Hagerstown, MD…..2190#
A/A......10/14/06....Norman Foster.............1/8 Mile ET.....7.355………….’81 Challenger…..Piedmont, NC…..….2300#
A/A......10/14/06....Norman Foster.............1/8 MPH.........92.39MPH……’81 Challenger….Piedmont, NC…..….2300#
Nitrous
A/N......5/19/02......Will Burns...................1/4 Mile ET....10.943………….’67 Barracuda……Columbus, OH……….XXXX#
A/N......5/19/02......Will Burns...................1/4 MPH.........125.53MPH….’67 Barracuda…..Columbus, OH……….XXXX#
A/N......5/8/04........Will Burns...................1/8 Mile ET....7.042……………’67 Barracuda……Farmington, NC…….XXXX#
A/N......5/8/04........Will Burns...................1/8 MPH.........99.752MPH….’67 Barracuda… Farmington, NC…….XXXX#
Unlimited
A/S......4/19/08......Dale Rose....................1/4 Mile ET....10.012…………’?? Arrow…………..Bowling Green, KY…XXXX#
A/S......4/19/08......Dale Rose....................1/4 MPH........132.82MPH….’?? Arrow…………..Bowling Green, KY…XXXX#
A/S......5/8/04........Tom Drake..................1/8 Mile ET....6.102……………’38 Simca…………..Farmington, NC…….2315#
A/S......5/8/04........Tom Drake..................1/8 MPH........109.89MPH…..’38 Simca………….Farmington, NC…….2315#
Weight of 2350 -2699#
Class .......Date.............Driver....................Record.........ET/MPH..........Car…................Location……………….Weight
Gas Only
B/G......9/12/10.....Mark Etheridge............1/4 Mile ET.....11.50……………’62 Valiant………….Sacramento, CA….XXXX#
B/G......7/17/11.....Mark Etheridge............1/4 MPH..........114.860MPH..’62 Valiant………..Eureka, CA……………XXXX#
B/G.....10/14/06....Seymour Pederson.......1/8 Mile ET......7.333…………..’62 Valiant…………Piedmont, NC…..….XXXX#
B/G.....10/14/06....Seymour Pederson.......1/8 MPH..........91.91MPH…….’62 Valiant…………Piedmont, NC…..….XXXX#
Alcohol Only
B/A......9/6/03........Brent Laney................1/4 Mile ET....10.710…………’62 Lancer………….St. Louis, MO…………2445#
B/A......9/6/03........Brent Laney................1/4 MPH........120.81MPH….’62 Lancer………..St. Louis, MO………….2445#
B/A......5/13/06......Ron Hamby.................1/8 Mile ET.....7.600…………..’66 Dart…………….Farmington, NC.......XXXX#
B/A......5/13/06......Ron Hamby.................1/8 MPH.........87.783MPH….’66 Dart…………….Farmington, NC.......XXXX#
Nitrous
B/N.....7/12/08......Doug Dutra..................1/4 Mile ET....12.845………….’62 Lancer…………Samoa, CA…………….XXXX#
B/N.....7/13/08......Doug Dutra..................1/4 MPH.........103.93MPH….’62 Lancer…………Samoa, CA…………….XXXX#
B/N..............................OPEN RECORD......1/8 Mile ET
B/N..............................OPEN RECORD......1/8 MPH
Unlimited
B/S..............................OPEN RECORD......1/4 Mile ET
B/S..............................OPEN RECORD......1/4 MPH
B/S..............................OPEN RECORD......1/8 Mile ET
B/S..............................OPEN RECORD......1/8 MPH
Weight of 2700# - 3199#
Class.......Date..............Driver....................Record.........ET/MPH………….Car……………………Location……………….Weight
Gas Only
C/G.....9/11/11......Mark Ethridge...............1/4 Mile ET....11.921…………’62 Valiant………….Sacramento, CA.……XXXX#
C/G.....9/11/11......Mark Ethridge...............1/4 MPH........109.604MPH..’62 Valiant………..Sacramento, CA.……XXXX#
C/G.....10/14/06....Gary Bruner..................1/8 Mile ET....7.873…………..’64 Valiant…………Piedmont, NC..........XXXX#
C/G.....10/14/06....Gary Bruner..................1/8 MPH........86.77MPH…….’64 Valiant………..Piedmont, NC..........XXXX#
Alcohol Only
C/A.....10/11/09.....Jason Davis..................1/4 Mile ET...11.279………….’74 Dart Sport……Clay City, KY………….XXXX#
C/A.....10/11/09.....Jason Davis..................1/4 MPH.......114.22MPH…..’74 Dart Sport…..Clay City, KY………….XXXX#
C/A..................................OPEN RECORD..1/8 Mile ET
C/A..................................OPEN RECORD..1/8 MPH
Nitrous
C/N......9/10/05......Mike Jeffrey.................1/4 Mile ET....10.542…………’68 Valiant………….St. Louis, MO…………XXXX#
C/N......9/10/05......Mike Jeffrey.................1/4 MPH........125.25MPH….’68 Valiant…………St. Louis, MO…………XXXX#
C/N......8/23/08......Charlie Schmid............1/8 Mile ET.....8.319…………..’66 Barracuda……Knoxville, TN…………3250#
C/N......8/23/08......Charlie Schmid............1/8 MPH.........80.026MPH….’66 Barracuda…..Knoxville, TN…………3250#
Unlimited
C/S......8/22/10......Ryan Peterson.............1/4 Mile ET.....10.910…………’66 Valiant…………Kearney, NE………….XXXX#
C/S......8/22/10......Ryan Peterson.............1/4 MPH.........124.87MPH….’66 Valiant………..Kearney, NE………….XXXX#
C/S...............................OPEN RECORD.....1/8 Mile ET
C/S...............................OPEN RECORD.....1/8 MPH
Weight of 3200# or more
Gas only
D/G.....9/11/11......PJ Jesiolowski...............1/4 Mile ET....14.124…………’72 Demon………..Sacramento, CA…….XXXX#
D/G.....6/4/11........Dennis Schumers.........1/4 MPH.........96.640MPH….’66 Valiant…………Kearney, NE………….XXXX#
D/G..............................OPEN RECORD.....1/8 Mile ET.......
D/G..............................OPEN RECORD.....1/8 MPH..........
Alcohol
D/A..............................OPEN RECORD......1/4 Mile ET.......
D/A..............................OPEN RECORD......1/4 MPH..........
D/A..............................OPEN RECORD......1/8 Mile ET.......
D/A..............................OPEN RECORD......1/8 MPH..........
Nitrous
D/N......5/23/11.....Charlie Schmid.............1/4 Mile ET....13.362………….’66 Barracuda……Hagerstown, MD……3250#
D/N......5/23/11.....Charlie Schmid.............1/4 MPH.........99.65MPH…….’66 Barracuda…..Hagerstown, MD…..3250#
D/N..................................OPEN RECORD.....1/8 Mile ET.......
D/N..................................OPEN RECORD.....1/8 MPH..........
Unlimited
D/S......6/4/11........Lou Madsen.................1/4 Mile ET....14.982…………’68 Dart……………..Kearney, NE…………3410#
D/S......6/4/11........Lou Madsen.................1/4 MPH........95.29MPH…….’68 Dart…………….Kearney, NE…………3410#
D/S......7/23/11......Lou Madsen.................1/8 Mile ET....9.420……………’68 Dart……………..Elk Creek, VA……….3410#
D/S......7/23/11......Lou Madsen.................1/8 MPH........72.50MPH…….’68 Dart…………….Elk Creek, VA………..3410#
Seymour sent me the updated official Slant 6 records. Looks like PJ Jesiolowski took the ET record for D/Gas, and Mark now holds the A,B,C Gas records. The C/Gas record had stood for over 6 years prior. Congratulations to Mark and PJ on the new records. It's great having so many new records being set.
PostPosted: Fri Feb 10, 2012 5:41 am
Rob, a big thanks for listing the car and where the record was set. I know it was a lot of trouble and it took you away from your car projects. The weight of the Lancer for the alcohol only B/A record was 2445 lbs.
Thanks again,
Mark
PostPosted: Fri Feb 10, 2012 6:32 am
Mark, I think that record will stand for a while yet! Great work.
I edited to correct Brent Laney's name spelling, and added my Dart racewt - 3410.
Thanks again, Rob!
PostPosted: Fri Feb 10, 2012 7:38 am
It's really my pleasure to do it. It's a way I can contribute.
It doesn't really take me away from my projects. I have a 9-12 hour a day desk job and family commitments that do that. :lol:
I bring my binders with all of my SSRNs and schtuff into the office from time to time and do the research on my lunch break or early morning/late evening when things are more quiet.
I agree with Lou on that record lasting for quite awhile still. :wink:
PostPosted: Sat Feb 11, 2012 8:27 am
I went through and figured out where all of the records were set. Piedmont must be a fast track and in 2006 they had some good weather! :shock: :D
Seymour said that not all racers claimed an actual weight. Rather they simply said what class they were in. A few people have given me their actual weights. Others may not want that posted perhaps.
PostPosted: Sat Feb 11, 2012 10:37 am
The eighth mile records set on 10/4/06 were at Piedment, NC not Farmington.
PostPosted: Mon Feb 13, 2012 8:17 am
I've changed all of the 10/14/06 records from Farmington to Piedmont.
 Post subject: Update...?
PostPosted: Fri May 18, 2012 12:22 pm
With all of the records set and re-set lately out on the West Coast and at Mo-Kan, could you fellers that keep this data chit chat a bit this weekend at the Mason-Dixon race and let us all know what the latest and greatest is please... :D
(I know you'll be busy racin' and all, but there'll be some bench racin' goin' on too... :wink: )
PostPosted: Fri May 18, 2012 9:14 pm
I would like to see the records up dated,,,I know of three that need changeing.Guzzi Mark
PostPosted: Sat May 19, 2012 7:14 pm
Will talk to Ryan and Seymour tomorrow (Sunday at Mason-Dixon) about updating records.
Charlie S inched his D/N record down today (13.27 @99), and he put in his 175 HP jets (after runnering up the race) to try to hit the 12s tomorrow.
I dropped the D/U record today (14.39 @ 98), and might try to lower it tomorrow if we get a chance.
 Post subject: Records 5/26/12
PostPosted: Sat May 26, 2012 1:49 pm
Slant Six Racing Records May 26th 2012.
Gas Only
Alcohol
Nitrous
Unlimited
Gas Only
Alcohol Only
Nitrous
A/N......5/5/12......Mark Etheridge.............1/4 Mile ET.....10.576………….’62 Valiant……Sacramento, CA……….2300#
Unlimited
Gas Only
Alcohol Only
Nitrous
B/N.....5/4/12......Mark Etheridge............. ...1/4 Mile ET....10.594………….’62 Valiant…………Sacramento, CA…………….2370#
B/N.....5/4/12......Mark Etheridge................1/4 MPH.........122.572MPH….’62 Lancer…………Sacramento, CA…………….2370#
Unlimited
Gas Only
Alcohol Only
Nitrous
Unlimited
Gas only
Alcohol
Nitrous
Unlimited
Sorry it took so long to get this updated. There will probably be more records to add from the Mason Dixon Race very soon. Please let me know if you see any errors.
Ryan
Ryan Covalt
