It is currently Fri May 22, 2026 8:26 pm
PostPosted: Sat Feb 11, 2012 5:51 am
I have a 535 trans(I think) From a 3.9 Dakota. If someone is interested, make me an offer. Have the 3.9 bellhousing, flywhell, clutch (no very good), hydro T.O. setup. I will be traveling from Florida up to Virgina, and then to Pigeon Forge, Tn at the end of this week, so could bring it with me.
PostPosted: Sat Feb 11, 2012 6:05 pm
Kesteb, would you be willing to part with that bellhouseing? Im in the process of trying to figure out what trans- transfer cases i can get mounted behind a slant. Looks like choices are pretty limited. Would really like to have o.d. as it will be my daily drive, but may have to go with n.p.435 if i cant confirm a 535 will fit. Running 2 wheel drive with 833 now, so either way iwill need new bellhouseing. Is yours aluminum or cast iron. Rooster
Do a PM, I have the complete setup. cast iron bell housing, flywheel, pressure plate, clutch disk, fork and throwout bearing.
PostPosted: Sat Feb 11, 2012 7:48 pm
charrlie what does that hydro setup look like ??
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sun Feb 12, 2012 4:23 am
-Mike
It is under the shelf, out of sight for a few years, but if I remember right, it is a slave cyl that pushes the fork. I will look later today, to be sure, after the temps get above freezing.
PostPosted: Sun Feb 12, 2012 6:58 am
haha yea its pretty cold up here in Jacksonville too, man i was kinda hoping it was an internal thowout,
-Mike
PostPosted: Sun Feb 12, 2012 12:23 pm
Hydro slave cylender bolts right to the bell housing, with the pushrod, inside the bell. The complete fork is inside the bellhousing.
PostPosted: Sun Feb 12, 2012 2:02 pm
just googled it....... kinky but wont work for me :(
-Mike
