It is currently Fri Nov 13, 2026 8:43 pm
 Post subject: Valve Spring Help
PostPosted: Sat Feb 11, 2012 7:39 pm
ok so im gonna comfirm tomorrow but i think my Erson valve springs are takin a dump...
here are the part number for them... i cant seem to find any specs on them though...
what are you guys running a 6K revin solid cammed motor?
looking for around 120 seat/380 open
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sat Feb 11, 2012 8:28 pm
380 open seem like a lot. Did you test the valve springs when they were new by any chance? Have you pulled a couple to test them
PostPosted: Sat Feb 11, 2012 8:30 pm
well new springs lose 15-20% within the first heat cycle so about 300 would be perfect...
but no when i installed the springs that was above my knowlodge of things to check lol...
gonna pull them tomorrow and check them... if they are bad i might just pull the head and mill some more for a better static... still trying to figure out to use seat to seat (7.45) or @.050 (8.37)
PostPosted: Sat Feb 11, 2012 8:33 pm
Ed-
Any luck fixing the "cut out" problem you were having? Is this related to that?
PostPosted: Sat Feb 11, 2012 8:39 pm
Ed-
yea the MSD box went in today, along with the rebuilt/recurved dizzy with blue streak cap (game up on rotor)... runs better but didn't help the miss...
i know the pump was on marks 11 second almost 100hp more drag car so the pump is fine...
not much left lol
PostPosted: Sun Feb 12, 2012 1:40 am
How many years/miles on these springs? What are cam specs again? In my experience, it takes a long time for valve springs to fatigue. What are the symptoms?
I have had it happen to me once with a cheap set of 1.26" diam single 350 chev springs after about 50k miles on a MP 276 deg, 0.490" cam. Another time, I had about 40-50k on my 250 @ 0.050, 0.510" cam and the shop said the springs were weak but it would still rev well to 6000.
Hmmm,
PostPosted: Sun Feb 12, 2012 5:58 am
i have a dual sb dodge rated at 139lbs at 1.70" , 390lbs at .500 lift, there rated for .610" lift. i have them installed at 1.68" and running 556" lift. i have been racing them for 12yrs now no problems
PostPosted: Sun Feb 12, 2012 7:01 am
built the motor in the end of 09, has about 12K or so on the motor... can is 246 @ .050 .340 lobe
Hmmm,
PostPosted: Sun Feb 12, 2012 8:51 am
300 lbs open should be plenty, I would think, for that cam. Only way to know is to test them, I guess. 12k miles should not be too much. I'll be interested to see what you find.
PostPosted: Sun Feb 12, 2012 11:01 am
2x... just finished my home made on the car valve spring remover which i can start making for people if need be... let you know how it works!
PostPosted: Sun Feb 12, 2012 12:45 pm
ok so checked a cylinder...
they were...
75lbs @ installed height of 1.72
250lbs @ compressed height of 1.26...
way off...
so im now in the market for springs...
