It is currently Thu May 28, 2026 9:57 am
PostPosted: Sun Feb 12, 2012 5:27 pm
Here is my old dash: (note the pushbutton AM radio)
and here is my current dash: (note the toggle switch on the right where the old radio was, thats my "Hi-beam/Lo-beam switch instead of the old foot switch)
My question:
Should I fit the old radio (which is not working) or fabricate a blankin' plate and blank-off the hole, paint it the same gloss black and have a more cleaner look?
Any suggestions or comments on this are welcome :)
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Mon Feb 13, 2012 3:29 pm
I like music,, so if was me I would fix or replace the radio,
There are shops that can install modern (AM-FM-satellite-USB) workings behind the OE style face plates, to maintain the vintage look..
PostPosted: Mon Feb 13, 2012 4:56 pm
I like music and NPR, so I need a radio. I also like not having my radio stolen. Have you considered leaving the dash empty and installing the radio in an overhead console?
PostPosted: Mon Feb 13, 2012 5:47 pm
I had no trouble finding a SAM manual for the old AM radios and found that they were generally easy to fix unless the output transformer was fried; then I couldn't find a replacement. The most common problem is a dead power transistor, and those are very easy to replace.
PostPosted: Mon Feb 13, 2012 6:09 pm
The thing is, i rarely listen to music/radio when i drive - the engine is my radio.
Secondly, there are no AM stations anymore here in Malaysia, so even if the radio works, I cant listen to anything.
I was more interested on what to do with the hole for the old radio - put the non-working old radio in there or blank off the hole.
Thanks for commenting though, appreciate it.
Syed
PostPosted: Mon Feb 13, 2012 6:18 pm
i say put the radio back. if it's just a matter of looks, i'd say any little bit of "architecture" is better than a flat plate......
-proud new owner of a '61 lancer 170
-previous owner of a '74 dart swinger (R.I.P.)
-coming here for some schoolin'
PostPosted: Mon Feb 13, 2012 6:22 pm
Im with twentyshots on this,if you dont want a working radio,just put your broken am in for looks.
PostPosted: Tue Feb 14, 2012 5:35 am
Cool idea Reed, when the top goes down, it becomes a hidden radio… LOL
PostPosted: Tue Feb 14, 2012 6:25 am
Delete plate or Original AM radio, and put a Good Stereo in the Glove Box.
1964 Dart GT
PostPosted: Tue Feb 14, 2012 9:00 am
Whoops! I forgot your car was a convertible.
You could put gauges in the old radio hole.
PostPosted: Tue Feb 14, 2012 9:50 am
Thanks - it never occurred to me that there might be no AM in your area! I have a FM->AM converter box in my '71 just for nostalgia's sake.
PostPosted: Wed Feb 15, 2012 9:39 am
Put the old radio back in there. Unless the car is a drag car, radio delete plates look tacky IMO. Nothing looks better in that hole than the original radio.
