It is currently Sun Nov 15, 2026 5:41 pm
PostPosted: Sun Feb 12, 2012 3:59 pm
I'm planning on pulling the small block out of my 72 Dart bracket car this coming summer and putting a Slant in. Can this be done with out changing the k frame?
1971 Dodge Dart 42k original miles
 Post subject: No easy way...
PostPosted: Sun Feb 12, 2012 5:22 pm
If you have some sheetmetal and a welder it could be done. The market has always been geared for tearing our engine out and putting in a V-8. No one has had much interest to make a kit to do the reverse as of yet. So you can swap a K-member or make some adaptor mounts up.
Good Luck,
PostPosted: Sun Feb 12, 2012 6:03 pm
I have always had a intrest in racing a slant plus I have a handicapped daughter so If I slow down to the 14 sec zone she can ride with me at the track. A experince the kid loves when I used to take her to my local outlaw track. But I would like to come up with some kidda mount system instead of a k frame change
PostPosted: Mon Feb 13, 2012 6:10 am
Ask around with parts wanted.There was a guy "Ed" that was making engine plates and had some with him at last years Mopars at the strip.Maybe someone will know how to get ahold of him.
PostPosted: Mon Feb 13, 2012 6:12 am
He and his wife ran a clean red Demon.They were from California.
PostPosted: Mon Feb 13, 2012 7:07 am
Yes, Edd Jesiolowski (sp?) was making these "elephant ears" motor plates a while back, quite reasonably. I bet it wouldn't be too hard to fab up from spacer plates/brackets to mount the Slant on a V8 K. The pass side might actually be a bolt in, but driver side will be a little tougher.
There are a few Slant 6 racers in Pittsburgh area, so it might be good to hook up with those guys. Greg Ondayko is the main dude.
Welcome!
PostPosted: Mon Feb 13, 2012 9:48 am
It is pretty easy to make a pair of special engine mount brackets to allow for V - 8 to SL-6 swapping.
You have the right K-frame for it... the V -8 one with the "lower" driver's side mounting position.
The last one of these I did was on my 68 B-cuda. (pictured below)
That car had the later V -8 "spool mount" K-frame in it, and we ran big blocks, small blocks and the SL6 in the same car, using special brackets.
It was always fun to go to the track after running the SL6... then swapping the BB into the car, people would wonder how you got 3 seconds out of the car... during the week in-between. :lol:
PostPosted: Mon Feb 13, 2012 3:37 pm
I actually thought the drivers side was the same on a slant k frame as a small block k frame I thought the difference was on the passengers side.
Is this correct?
PostPosted: Mon Feb 13, 2012 3:41 pm
On a 72, the drivers side is up & and in-board on a SL6 K-frame.
 Post subject: Motor plates
PostPosted: Mon Feb 13, 2012 5:51 pm
My name is Edd. I am the one that makes the motor plates for slant six. and V8's.
Go to www.pacefabrication.net for more information.
530 518-4735
PostPosted: Mon Feb 13, 2012 7:33 pm
Yaha, That's the Man, I knew you were out there somewhere !! I'M marking this down this time.....
PostPosted: Mon Feb 13, 2012 7:44 pm
I will be getting Me an Edd's Motor plate next year for ruster.. The plan is to setback the Engine a few inches ad whack off a much of stock K frame as possible for ruster!
They Look Fabulous on The Website!
keep up the great work!
Buying next year!
PostPosted: Mon Feb 13, 2012 8:12 pm
I have one of Edd's plates and could bring it to M-D for people to handle, if someone's interested.
PostPosted: Mon Feb 13, 2012 8:18 pm
just throw it on the sacle and tell me what it weighs! :D
 Post subject: Scales
PostPosted: Tue Feb 14, 2012 3:28 am
The scales weigh 3 lbs. Any other questions? :shrug: :lol:
