It is currently Mon Oct 12, 2026 2:36 am
PostPosted: Thu Mar 01, 2012 5:00 pm
I did the trouble shoot for the 67 valiant because the same problem was going on but now when I check the starter relay I am only getting 8v from the ignition switch on the yellow lead at the starter relay. The ignition switch has been replaced, along with the starter relay, and the neutral safety switch. Does not engage starter in any gear, also the radio does not work in the start position but works with it on and when in acc mode.
Do unto others as you would have them do to you.
PostPosted: Thu Mar 01, 2012 7:15 pm
What is the battery voltage and what are you using as a ground for the volt meter when you check the voltage at the starter relay?
Nothing switched by the key except the ignition system and starter should operate when the key is in the Start position. The operation you describe with the radio is normal.
PostPosted: Thu Mar 01, 2012 10:36 pm
I am just using the side of the starter relay since I just replaced it and was getting 12v off the battery in the same place. Does anyone know where to find a wiring diagram for the complete car? I have no clue what the people did to this car before I had it, but there was no problem at all untill a week ago. I know that the buzzer is dead or disconnected and there is a light tied into the dome light for the floor board for when the door is open the light is on but when the dome is turned on it turns of the floor light. SO needless to say I have some electrical work to do
EDIT: Also there is 11v from the battery in the start position and 12v in off
PostPosted: Fri Mar 02, 2012 6:37 am
Wiring diagrams here, and here. 12 v at battery is low, have you fully charged the battery?
Also clean all battery connections, and ground connections to block from battery, and cylinder head to fire wall. Check condition of connection at starter.
PostPosted: Mon Mar 19, 2012 6:05 pm
New battery, ballast resistor, ignition switch, voltage regulator,Ignition switch,and starter relay...now i have no power to the fuse block. I have a little black wire off my ignition switch that had no matching wire on the wire harness (Not the huge red/black combo that has my accessory wire ran to it and seems to be tied into the fuse block?)
