It is currently Mon Nov 16, 2026 12:44 am
 Post subject: Tell me about this cam
PostPosted: Fri Mar 09, 2012 4:56 pm
About 5yrs ago I bought a new rebuilt short block with a P4286681 cam in it just wondering alittle about the chacteristics of this cam looks like this will finally be the summer I put it in my 71 Dart
1971 Dodge Dart 42k original miles
PostPosted: Fri Mar 09, 2012 5:02 pm
Purple Shaft # P4286681
Cam ID# DC 276-106
Duration 276*
Overlap 64*
Lift .490
Recomended install 102*
Lash int .016 exh .020
The engine's static compression ratio needs to be in the 9.8 - 10 to 1 range for that cam to work well so don't use it in a "stock" engine, with no other changes.
PostPosted: Fri Mar 09, 2012 5:18 pm
The engine is bored .06 and the head was milled if I remember right about .106 but I'm not sure I will be checking the cc's first and it will be alittle while before putting it all together The head was also lightly ported
