It is currently Sat Nov 14, 2026 4:10 pm
 Post subject: Valve seals?
PostPosted: Sun Mar 11, 2012 6:32 pm
I still have a few things left on my shopping list for an engine I want to start putting together pretty soon, among them: valve seals.
•VALVES: those EPN 1.70"/1.44" with 3/8" stems that "engnbldr" sells on e-Bay.
•CAM: Isky 152-116 (.448"/.448" lift )
•SPRINGS: Mopar P4286813 (single/damper).
•USAGE: street only
What seals would you guys recommend?
Thanks.
obliquely-inclined state of mind
PostPosted: Sun Mar 11, 2012 6:49 pm
Stock umbrellas.
PostPosted: Mon Mar 12, 2012 11:17 am
Thanks, Josh.
So do I have this right?
intakes are the shorties, e.g.:
•Felpro SS12764, Sealed Power MV 1771
exhausts are taller, e.g.:
•Felpro SS13955, Sealed Power MV1918
And, while we're on the subject, school me on Viton vs. rubber, please.
Thanks.
PostPosted: Mon Mar 12, 2012 11:29 am
The other way around on the "tall & short" seals... the tall ones go on the intakes. ( they need less oil)
Get the Viton seals, those last a lot longer.
PostPosted: Mon Mar 12, 2012 1:32 pm
Boy, what a knuckledhead: was out rummaging in the garage and found some Fel-Pro and ROL gasket sets I'd forgotten I had (which include valve seals). Unfortunately, they all appear to be polyacrylate, not Viton.
Rock auto lists:
•Sealed Power MV1918 as being Viton exhaust valve seals and
•Sealed Power MV1771C as being Polyacrylate intakes.
Doc, got a mfg./part number for Viton intakes, or are they only preferred on the exhaust valves (a far less hospitable environment, I would assume).
Thanks.
PostPosted: Mon Mar 12, 2012 2:04 pm
Couple of interesting links on various seal compounds:
http://www.pspglobal.com/low-temperature-seals.html
http://www.sealanddesign.com/category/R ... s/462.html
_____________
Doc,
I notice that Viton seals seem to be a somewhat controversial topic in some circles. Don't get me wrong: I have nothing but respect for your years of accumulated slant knowledge. However, I have noticed lots of complaints about Viton seals (cracking and leaking) in street engines on other car forums and even here, from Slantzilla (hard on guides?):
http://www.slantsix.org/forum/viewtopic ... ton#233776
This engine of mine will likely not see a lot of high RPMs.
PostPosted: Mon Mar 12, 2012 2:11 pm
The Poly seals will be fine, use those, they are good to 350+ degrees.
Some of the confusion on Viton seals is that most of the Viton seals are "positive seal" designs, not the umbrella type.
See this article for more info on valve stem seals:
http://www.enginebuildermag.com/Article ... signs.aspx
PostPosted: Mon Mar 12, 2012 2:12 pm
Polyacrylate is the material the factory used for the upgraded valve stem seals in heavy-duty truck versions of the slant-6. Those are the ones I tend to buy.
PostPosted: Mon Mar 12, 2012 2:27 pm
Great article! Thanks, Doc!
PostPosted: Mon Mar 12, 2012 2:30 pm
"Polyacrylate is the material the factory used for the upgraded valve stem seals in heavy-duty truck versions of the slant-6."
So I guess the early, OEM ones were nitrile?
PostPosted: Mon Mar 12, 2012 2:43 pm
Without looking it up, almost certainly yes -- my guess would be nitrile.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 9 guests
