It is currently Fri Nov 13, 2026 4:04 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Mon Mar 12, 2012 1:29 pm
did the swap and with #2 in #1 hole, got .020. so crank is ok.
i don't have any micrometers, so using a dial caliper i measured the two pistons that are out of the block, bottom of skirt to top of piston, and top of pin bore to top of piston, and i am convinced the piston is ok. so i believe i need a replacement rod, which will hopefully measure .010 - .013 longer. then all piston heights would be within .003.
i will remove the remaining pistons, mark the head as described and match the chambers to the bore. good stuff.
thanks, andy. 8)
84 D100 /6 long rod 225
86 D100 /6 my sons w/offy intake/weber carb
2016 buick regal turbo
PostPosted: Mon Mar 12, 2012 2:15 pm
How the heck could those rods be off by that much - wow.
PostPosted: Mon Mar 12, 2012 2:26 pm
My guess... it's a slightly bent con rod. Likely out of an engine / cylinder that got water in a bore, and was started. ("Hydrauliced")
 Post subject: rod
PostPosted: Mon Mar 12, 2012 3:12 pm
Doc, if you may remember, the single rod you sent me a while back had a mismatched cap. i went through all mine and found the best fitting cap i had, the machine shop remachined it. the bearing to journal clearance was good, but maybe the machining was off. maybe bent, but either way i would consider it not usable. when i get another rod i will measure carefully before installing the piston.
have a great day, andy.
PostPosted: Mon Mar 12, 2012 3:32 pm
Yes... aggresive resizing of the "big end" can change the rod's C to C... but .010 is a lot.
PostPosted: Tue Mar 13, 2012 4:51 am
Oh, I thought those were new K1 rods. This is easier to stomach... knowing that these are used & reconditioned factory rods
