It is currently Fri Nov 13, 2026 2:58 pm
PostPosted: Mon Mar 12, 2012 5:06 pm
Car Model: 67 Valiant
I did a valve adjustment on my 67 valiant a couple weeks ago.
(Intake .010 Exhaust .020)
It was a major improvement in a lot of ways. Except now my PCV valve is whistling, and when i pop it out and shine a flashlight on the hole, i see a little smoke.
the valves were way out of whack. When i was done with the adjustment i was pretty happy with how it went.
Maybe it smoked before.....but would anything about a valve adjust cause my engine smoke?
PostPosted: Mon Mar 12, 2012 5:12 pm
6 Pack Dart
Smoke is blowby normal for old high milage motor, try new PVC valve.
Richard
PostPosted: Mon Mar 12, 2012 5:15 pm
Re-adjust the idle speed, that may stop the PCV whistle.
PostPosted: Mon Mar 12, 2012 5:54 pm
you did remember that the valves change sides at 3 - 4 intake are side by side
PostPosted: Mon Mar 12, 2012 6:12 pm
ya, pretty sure i got the intakes and exhausts right.
PostPosted: Mon Mar 12, 2012 7:48 pm
And you adjusted hot/running, not cold, right?
PostPosted: Mon Mar 12, 2012 8:22 pm
yup, engine runnin' and warmed up. idling low
I'm pretty sure i navigated the intake and exhaust combo alright, but what if i did get one backwards? hypothetically.
What would happen if one of my intake valves was adjusted to the exhaust spec. or vice-versa?
PostPosted: Mon Mar 12, 2012 9:28 pm
6 Pack Dart
Should run rough, which you don't indicate.
Richard
Users browsing this forum: Bing [Bot], eric22t and 4 guests
