It is currently Thu Nov 12, 2026 3:29 pm
Post new topic  Reply to topic  [ 42 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Aug 08, 2011 9:11 am
The first thing I do when assembling a SL6 intake to exhaust manifold, is to bolt the two manifolds together, at the "hot box", with-out the gasket, align them the best I can, then inspect the "mocked-up" assembly.
If you can not get the two manifolds to seat flat & evenly together, figure-out why and correct... before attempting the final assembly and alignment, with the gasket.
If the surface between the two manifolds does not allow for good "full contact"... any gasket you attempt to use, will eventually fail.
Most often cause of trouble... a badly warped exhaust manifold.
I grind and "fiddle" until I get the manifold to manifold mating surface correct, while watching the manifolds to head (port face) surface... trying to keep them even.
After assembly, we grind the port face surface flat and sometimes have to port-out the port opening(s) to adjust for the warpage.
PostPosted: Fri Aug 12, 2011 10:33 pm
We ended up using the Aussie gasket / RTV-on-metal-gasket combo and it seems to be holding up, so far. Left a thick bead of high-temp silicone on the metal gasket overnight to cure so it would be a little more built-up. Also had to double up on the exhaust pipe gasket. Must be something out of whack on Aaron's exhaust system.
PostPosted: Fri Aug 12, 2011 11:19 pm
Yep, I just coated both sides of the gasket with copper RTV and made sure I bolted everything on properly. Let it set-up overnight and then ran the motor for 5 minutes to heat-cycle the RTV sealant, and left it alone for the rest of the 24 hour cure period. Also RTV'd the downpipe exhaust gasket, but don't think it was needed.
So far so good. Quiet exhaust :)
If it leaks again, I'll use the opportunity to get some head-work done and maybe a new cam. Also install the cloyes double roller timing chain and aluminum valve cover sitting under my bed.
PostPosted: Sat Aug 13, 2011 12:40 am
Anything wrong with the heat riser metal gasket and intake gasket that came in my felpro set?
PostPosted: Sat Aug 13, 2011 2:30 am
They're too thin, unless you have perfectly flush mating surfaces... Which isn't likely after 30-40 years :)
If I were to use the metal gaskets, I'd sparingly coat them on both sides with Copper RTV sealant. The gaskets may or may not work as it seems to be a crapshoot.
Probably better to use the thicker Aussie or Remflex gaskets.
PostPosted: Sat Aug 13, 2011 7:33 am
What Jester said. Those stamped steel "gaskets" almost never seal. Maybe they worked okeh when everything was brand new, but the odds are against your getting even a half-decent seal, even if you goop it up with RTV. It sucks having to do all the heavy lifting again; worth your while to wait for a Remflex or Aussie gasket.
PostPosted: Sun Aug 14, 2011 5:09 am
I have the Aussie Gaskets in stock. PM me for price and shipment.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Dec 30, 2011 1:47 pm
im wondering should i spend the money on a remflex/aussie gasket, or use the felpro gasket, i do have that blue hallomar stuff in my drawr, which i read can be used in the installation article.
PostPosted: Fri Dec 30, 2011 2:20 pm
If the manifolds are flat the Felpro manifold to cylinder head gasket works fine.
PostPosted: Fri Dec 30, 2011 3:52 pm
Do you feel lucky? If the manifolds are in very good condition and alignment, the Fel-Pro gasket will probably work to seal the manifold-to-head junction. The odds are very much against the stamped-metal hot box gasket sealing for you, though.
Not a good gamble; this job is a pain in the rear and I try to minimize the number of times I have to do it. So I advise waiting til you have the good gaskets in hand unless it's a real emergency, needed-vehicle-off-the-road situation.
 Post subject: Spacing...
PostPosted: Fri Dec 30, 2011 5:52 pm
The remflex "hotbox" gasket is almost 3/16" thick and compresses to a little under that. It should work fine if you have two mismatched manifolds and the exhaust hotbox is a little short (sometimes happens if using an earlier manifold and a super six intake). If you need one of those I have a few hanging around I'd sell for $5+ postage, since I get the remflex gasket kit, but have no use for the hotbox gasket, they just hang out in my misc. gaskets box.
PostPosted: Tue Mar 13, 2012 10:02 am
