It is currently Wed Nov 11, 2026 12:53 pm
 Post subject: ebay valves
PostPosted: Mon Mar 12, 2012 5:53 pm
any body see these valves 300 ford Item number:
270786862573 just wondering what everyone think of these for a performance build.
PostPosted: Mon Mar 12, 2012 7:28 pm
Site Admin
I think they are going to touch each other in a slant head. :lol:
What overbore have you got?
Your going to need a minimum .060 over, and they are going to mask on the bore pretty heavily. I have 1.540" Exhausts that have been face and back cut to keep them off the cylinder walls.
If your running 0.100" Overbore, it may not be an issue, but make certain to correct the dowls if the chambers don't precisely center over the bore. I bent three exhaust valves when they wacked the cylinder wall.
My gut reaction is; Too Big.
CJ
PostPosted: Tue Mar 13, 2012 1:55 am
i am using 360cid valves cut to 1.80int/160ex with a notched .060 over bore. i am thinking of doing a new head and have read here of some members using 300cid ford valves. the head i have has rusted through #6ex port and ex valves are pitted bad from sitting to long as backup motor. the engine it going on is my .080 over blown engine. just wondering if these are the valves most use i know i will have to do everything for 11/32 stems.thanks terry
PostPosted: Tue Mar 13, 2012 4:55 am
Most racers I know have found that 1.76/1.50 is about as big as you want to go on a 0.100" or less overbore motor. Valve shrouding takes away any gains with bigger diameters. I have seen a 1.84/1.44 head where the int valve was moved toward the middle about 0.040-0.060". That worked well.
I have a 1.84/1.54 head I bought off a racer 15 yrs ago and it has never been run. About 0.025-0.030" between the valves, so at the limit. I keep looking for a combo it would work with...
PostPosted: Tue Mar 13, 2012 11:49 am
6 Pack Dart
Have thom in both my motors
Richard
PostPosted: Tue Mar 13, 2012 12:00 pm
When I did a big valve head around 1999 I used Ford 300 valves and had the exhausts cut down to 1.45". That head was used on a 3.43" bore engine.
PostPosted: Tue Mar 13, 2012 12:01 pm
I took the easy way out and used the ebay engn builder valves with .040 overbore.
Kev
PostPosted: Tue Mar 13, 2012 3:18 pm
fopar did you use the 4.75" or the 4.81" over all lenght valves? the sb dodge valves i have are 4.77" length.
PostPosted: Tue Mar 13, 2012 3:37 pm
6 Pack Dart
I didn't measure the machine shop did the work. From what I recall the Ford valves are 0.010" longer than the slant valves.
Richard
Users browsing this forum: Amazon [Bot] and 7 guests
