It is currently Mon May 25, 2026 8:06 pm
PostPosted: Wed Mar 14, 2012 8:19 am
my 2 door hardtop swinger slightly sags in the rear and to the left about 1/4 inch. i am awear of all the spring options out there. has anyone used the monoe # 58496 . its a coil over shock "booster" . im just looking to level out the rear sag. basicaly 1 inch on the right and 1.25 inch on the left. im wondering if these coil over shocks will do the trick>?
any input ?
PostPosted: Wed Mar 14, 2012 8:40 am
Bad solution. Top shock mount isn't designed to be a support for the vehicle. The stress can cause the top shock mount to fail.
It also doesn't do much for handling, either.
I was very pleased with the hi-lift springs I got from JC Whitney, they had a "free shipping" offer which made them very attractive in price.
Do it right and be happy the first time around! :lol:
- Mac
PostPosted: Wed Mar 14, 2012 9:33 am
i realize top shock mount isnt designed to carry ALOT of load. again my original leafs are not that that bad, just sag about 1 inch on each side. Thus i cant emagine these shocks ripping through the body. no one rides in the back and i dont carry any weight in the trunk or tow, thus the coil over is just leveling out the a$$ end ??? iduno. new leaf and harware is 300 bucks for pair. new monroe coilover is 70 bucks for the pair
PostPosted: Wed Mar 14, 2012 10:15 am
If you want helper springs get the leaf type. http://www.amazon.com/Superior-11-1020- ... B00029K022
20 years ago I used nearly identical springs on my '73 Duster to get the back end up where it belongs.
PostPosted: Wed Mar 14, 2012 10:31 am
http://www.jcwhitney.com/john-r-spring- ... 413y1968j1
$84.13 per side. Plus the shackle hardware, which is likely suffering from worn bushings anyhow.
Free shipping through this Saturday.
Another solution (less expensive) is to bring your springs to a spring shop to have them re-arched. I did that on my 74 Valiant, and they held the new arch for several years.
I think the decision rests on what you intend to do with the car. Obviously the springs are spent. If the car is a keeper, then save up and replace the springs. If it's something you're going to get rid of in a couple of years, then any of the other solutions will do fine.
- Mac
PostPosted: Wed Mar 14, 2012 1:34 pm
thanks guys
