It is currently Wed Dec 31, 2025 11:19 am
 Post subject: transmission questions
PostPosted: Wed Mar 14, 2012 12:35 pm
I pulled motor/trans out of Marys 1969 dart parts car
these are the photos of the trans. it is marked 1971
can i run this trans in our 1968 dart
I think our motor is 1970 in our dart too.
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Mar 14, 2012 3:48 pm
If it is in fact a '71 trans it will bolt right together. :D
PostPosted: Wed Mar 14, 2012 4:13 pm
Yep. However, now is an ideal time for a fluid and filter change (ATF+4), band adjustment, shift kit install, and verification that it has part throttle kickdown.
PostPosted: Wed Mar 14, 2012 5:21 pm
how do you adjust the bands?
we have an old school transbrake reverse manual
need a deep pan/trans cooler.. 3/8's lines
thinking about a 3800 stall too
slant six's RULE!
PostPosted: Wed Mar 14, 2012 5:23 pm
You pulled the trans and engine apart with the torque converter still bolted to the flex plate? So much for the pump bushing and seal.
PostPosted: Wed Mar 14, 2012 5:32 pm
dude
this thing slipped off super easy
their very light
trans was drained
slant six's RULE!
PostPosted: Wed Mar 14, 2012 5:42 pm
Get a factory service manual and read the transmission section. It is very easy to do. However, I cannot say if the factory specifications and procedure will work with your aftermarket valve body. A more experienced racer needs to answer that question for you.
PostPosted: Wed Mar 14, 2012 7:45 pm
Is that an old Tranz-Act with the big can solenoid that screws into the neutral switch hole?
Do you have the little bent pin that goes between the solenoid and the valve body?
Do you have all the instructions for it? That is not a bolt-in and go valve body you know.
If you're not going to rebuild the trans do not put ATF+4 in it either.
PostPosted: Fri Mar 16, 2012 4:15 pm
Also, AFAIK if you have a non-stock ratio (like a 4.2 or 5.0:1) for the kickdown band lever, then you need a different "back the adjuster screw" count from the factory procedure. The service manual gives the basic idea of what to do for a stock trans.
63 Valiant Wagon
225 - 4 bbl
