It is currently Sun Nov 15, 2026 12:17 pm
 Post subject: 86 Ram hard start
PostPosted: Mon Mar 19, 2012 7:47 am
Car Model: 1986 D100 /6 A833od shortbox
Yesterday when I started my truck, well, it wouldn't. Turned over fine, with the smell of gas after a few tries. Popped the hood, removed air cleaner and fiddled with the choke a bit. Tried again, and it started, but not without generous gas pedal goosing. Any suggestions?
86 D100 short bed A833, lean burn deleted.
07 Honda Accord EX-L V6
03 Toyota Highlander - 305k and still going strong
13 Toyota Highlander - 151k
PostPosted: Mon Mar 19, 2012 7:55 am
Specs: Stock 225 with 1945 Holley non feedback
PostPosted: Mon Mar 19, 2012 10:35 am
I suspect an automatic choke malfunction. Clean linkage, check for bent, binding, or missing linkage. When engine is cold, remove air cleaner, rotate throttle by hand while observing spring action of choke heater, linkage, and choke closing action.
Dose everything move smoothly, with a bit of a snap, closed, or dose it kind of lazily almost close the choke but not quite?
You may have to repeat this procedure several times before you eye can catch all the action. Just open the throttle with one hand, while open back off high idle cam, and open choke butterfly to reset for a simulated cold start.
Sometimes the linkage pivot points become egged out a bit and will cause a binding; this can be corrected by a little bit of file work to dress the ridges just enough to allow things to move without hanging up.
Another problem is the bimetal spring becomes weak or broken and won’t push the choke closed.
The choke has to close with authority, stay closed until engine catches, and as soon as vacuum is present retract about 3/16th of an inch if the engine is to start easily. If choke won’t fully close, starting can be hard depending on how colt it is, flooding can follow due to excessive pumping causing a gas smell.
PostPosted: Mon Mar 19, 2012 11:59 am
like Bill said....choke must work right
PostPosted: Mon Mar 19, 2012 7:13 pm
Thanks guys-checking tonight
PostPosted: Tue Mar 20, 2012 8:41 am
Definitely a choke issue. Seemingly getting hung up on the choke stove. Also, the element in the stove seems to need "help" to properly choke. Ordering a new choke stove today. Thank you to wjajr and hantayo13 for your help.
PostPosted: Tue Mar 20, 2012 2:26 pm
I thought I saw a while back that I could order the choke thermostat on rockauto.com, but as of today, that is not so. Anyone have any suggestions where I might find one? My local NAPA is no help, btw.
PostPosted: Tue Mar 20, 2012 2:54 pm
You may order a new and improved electric choke kit from CarbsOnly. See HERE. I installed one of these on my brother's 83 Dodge van and it works beautifully. These kits are superior to the factory exhaust heat actuated assembly.
PostPosted: Tue Mar 20, 2012 3:11 pm
You might just need to take the choke stove off and shoot some PB blaster on the spring and work it back and forth until it loosens up. That's what I did on my 84 and it fixed the starting issues.
PostPosted: Sun Mar 25, 2012 6:18 pm
I have one on my 86 with 1920 and it works great!
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
