It is currently Fri Nov 13, 2026 6:56 am
 Post subject: carb gasket
PostPosted: Tue Mar 20, 2012 4:40 pm
my van came to me with a heat shield installed under carb to manifold - should there be a gasket both between the carb and shield, and shield to manifold - and if so can they both be the fel pro 60085 or should shield to manifold be thinner ? - oo3
69 a100 225 tree3
PostPosted: Tue Mar 20, 2012 6:29 pm
Is your heat shield made of sheetmetal or is it the more common gasket-material variety?
PostPosted: Tue Mar 20, 2012 11:58 pm
it is metal - oo3
69 a100 225 tree3
PostPosted: Wed Mar 21, 2012 12:03 am
Thick gasket (Fel-Pro 60125 will do) between the heat shield and manifold, thin gasket (60085) between heat shield and carburetor.
PostPosted: Wed Mar 21, 2012 4:13 pm
have a 60085 and ordered a 60125 - thank you - oo3
69 a100 225 tree3
