It is currently Thu Aug 13, 2026 11:29 am
 Post subject: Break in oil
PostPosted: Mon Mar 26, 2012 10:42 pm
Am going to use Lucas 30w I think it has the zinc and phospheru in it all ready. How long should I run it, 500 miles or what
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Mon Mar 26, 2012 11:02 pm
Wrong break-in. Brad Penn break-in oil they say to run for 500 miles.
PostPosted: Mon Mar 26, 2012 11:18 pm
Why that brand? Where can I get it? I am in corona ca , so the web.
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Mon Mar 26, 2012 11:55 pm
No, not the wrong brand. Wrong word. The brake slows the car. You want to break-in the engine. Brad Penn just happens to make a break-in oil and they say run it 500 miles.
PostPosted: Tue Mar 27, 2012 12:49 am
Brad Penn is good $#!+
PostPosted: Tue Mar 27, 2012 10:16 am
PostPosted: Tue Mar 27, 2012 10:41 am
It's a large error to use heavy/thick oil (whatever brand) to break in the engine. You need an extra-light weight of oil for the purpose.
PostPosted: Tue Mar 27, 2012 12:28 pm
I used Brad-Penn but changed it out after 100 miles. No issues.
11.02 @ 120.56
Chassis dyno
PostPosted: Tue Mar 27, 2012 12:53 pm
i run whatever oil i am going to run in engine ...change after cam run in and at 100 & 500 mile
PostPosted: Tue Mar 27, 2012 1:56 pm
There are a number of "cam break-in" additives out there...
I have been using the stuff from Comp Cams lately.
 Post subject: Yep...
PostPosted: Tue Mar 27, 2012 5:24 pm
The local mom and pop places calls this the "secret sauce"...It has moly in it so it's dark in color...I'm a bit put off by the other brand additive
that says "zinc" but is clear liquid the viscosity of honey...Last time I worked with some zinc it was grey in color not clear...
x2 for comp secret sauce
PostPosted: Wed Mar 28, 2012 11:44 am
I bought a couple of cases of STP oil conditioner of some thing like that. It is a 30W with bunches of zinc. Quart sized, not the thick goo in the pints. They quit making it.
I always run an engine 20-30 minutes for cam break in then drain, new filter and refill.
10-30 Rotella diesel oil will have all the zinc you need. Don't get the synthetic blend. Not until the engine is broke in.
PostPosted: Fri Mar 30, 2012 7:12 am
OK, now I am really confused. So what some of you are saying is that the zinc and phosphrus thing is a bunch of marking to sell a more expensive oil and that I should just run normal 30w. THE other half is telling me to us a " on " break in oil. Here is the thing in I am using my existing cam, for not so loved Clifford, So I have all ready broke or ran in the cam and lifters I am mainly worried about setting the rings and reducing blow by. And also I know that I can not spell you dont need to point it out lol. THanks
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Fri Mar 30, 2012 8:27 am
When you reply, see that block in the bottom right hand corner that says "spellcheck"??? It will help to show that you have some intelligence and not a hill jack. Just sayin.
PostPosted: Fri Mar 30, 2012 8:59 am
When I read this thread, I don't see what you seem to think you see. Perhaps you should read the thread more carefully.
