It is currently Tue Oct 13, 2026 3:33 pm
 Post subject: which distributor to us
PostPosted: Tue Mar 27, 2012 10:10 am
I have two different distributors, A mopar performace stock hei and one that has a ingnitor 2 that has been recurved. The only shop that i could find that will recurve the HEi on charges 100 hour for labor and then parts. what should it do?
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Tue Mar 27, 2012 10:42 am
There is nothing such as a "Mopar Performance stock HEI" distributor. If you mean that you have a Mopar Performance electronic ignition distributor, it would have come with extra-light advance weight springs. Not suitable for use on the street.
 Post subject: ????
PostPosted: Tue Mar 27, 2012 5:28 pm
If you have a car set up for points already run the ignitor...If you have EI, get the other one recurved (if it's a MP distributor and you are only drag racing-plug and play)... do you have a part number tag on the EI unit?
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
