It is currently Thu Jun 18, 2026 1:46 pm
 Post subject: Trans filler tube
PostPosted: Thu Apr 05, 2012 5:35 pm
First off, I'm not a great mechanic so take that into account. :oops:
I can't seem to pull my transmission filler tube off. It's a 904 in a 84 1/2 ton van. Yes I have the bolt out part way up the tube.
It leaks pretty bad out the front of the trans so I bought a used one to replace it with. So I poured the the old fluid out and man was it dark, took
the filter off and it looked as though it had some holes worn in the body under the filter?
Anyway, any advice on pulling off that filler tube without breaking something?
Thanks in advance.
If man made it, I can break it.
PostPosted: Thu Apr 05, 2012 6:21 pm
6 Pack Dart
Once you have the bolt out the tube should just pull out, it's held in with a O-ring seal.
Richard
PostPosted: Thu Apr 05, 2012 6:24 pm
Thanks Richard, ya, that's what I thought. Dam thing doesn't want to come out though.
PostPosted: Thu Apr 05, 2012 6:28 pm
The one on the used tranny I bought comes out easy, the old one not so much and since the old one has the length for a van and the replacement one came out of a truck and doesn't I dont want to damage it.
PostPosted: Thu Apr 05, 2012 7:48 pm
6 Pack Dart
Just a thought, the V8 trans I had got had another bolt down by the lower end of the tube it goes into the case. Take a look to see if yours has the second bolt.
Richard
PostPosted: Thu Apr 05, 2012 8:13 pm
Hmmm, I didn't see one but I,m going to take a flashlight out and check it out.
I did notice something that doesn't look good though, the two pans aren't the same. They both have 14 bolts but they are shaped a little different.
PostPosted: Thu Apr 05, 2012 8:35 pm
No, I don't see another one. I was going to post pictures of the pans but not sure how. I click Img and it just reads Img in the posting area.
Maybe I don't have picture privileges yet?
PostPosted: Thu Apr 05, 2012 9:51 pm
6 Pack Dart
Sounds like you might have a 727 and a 904.
(Click on this)
http://www.teufert.net/trans/trannyid.pdf
Richard
PostPosted: Thu Apr 05, 2012 10:21 pm
Crap, the trans in my van is a 904 and the one the junkyard sold me is a 727.
The thing is that they advertised it as a 914 and the truck they pulled it out of was a half ton dodge same year as my van with a slant six.
This doesn't make any sense to me.
PostPosted: Thu Apr 05, 2012 11:12 pm
6 Pack Dart
The 727 was used in trucks behind the slant 6.
Richard
PostPosted: Fri Apr 06, 2012 6:30 am
Site Admin
You need store the photos somewhere, like photobucket. Just copy the links for photobucket provides and paste them into your images.
The A727 has some value for truck guys. You should be able to turn it and get an appropriate A904. Just make sure it's of an appropriate year to match your engine. Not all parts interchange across the years.
CJ
PostPosted: Fri Apr 06, 2012 6:36 am
Thanks for all the help Richard, so is the 727 incompatible for my van without modifications?
I suppose I better do some measurements and some more research here. I think once I get that filler tube off I should try to figure out if my 914 is still in good enough shape to just stop the leak coming from the front and keep using it.
I was planning on rebuilding it and keeping it and just using the junkyard one in the interim. I'm pretty sure I have a lot of miles left on the motor and it's definitely still going to be my daily driver for work.
Thanks again.
PostPosted: Fri Apr 06, 2012 10:17 am
<a href="http://s1244.photobucket.com/albums/gg563/DouglasPaul/?action=view&current=100_1038.jpg" target="_blank"><img src="http://i1244.photobucket.com/albums/gg563/DouglasPaul/100_1038.jpg" border="0" alt="Photobucket"></a>
This is the stinkin' tube I haven't been able to get off. As you can see I'm making a mess with the leak. Drained the tranny and took off the pan. looks like I need to replace the seals but what else should I do to the front and is there a post on replacing the rear seal? :oops:
PostPosted: Fri Apr 06, 2012 10:53 am
Oh, and Fopar, thanks for the advice on posting pics if you didn't get my reply.
PostPosted: Fri Apr 06, 2012 11:00 am
6 Pack Dart
Only suggestion would be to make your pictures smaller.
Richard
Users browsing this forum: Ahrefs [Bot] and 3 guests
