It is currently Fri Jun 12, 2026 10:25 am
PostPosted: Fri Apr 06, 2012 10:13 am
Hello Sages,
Any Suggestions on geatting the Rear Piston Reinstalled for the Clutch Pack?
I put a New Rubber Seal and Lubed it up - It's tough to get in there..
I do Have a Press to use; I am just afaraid of rolling the lip on the Outer Seal.
PostPosted: Fri Apr 06, 2012 10:58 am
6 Pack Dart
A piece of Mylar sheet cut to not quite meet at the ends when installed into the hole you are trying to put the piston/seal into, will act like a tapered ring compressor. Leave enough Mylar in heighth to be able to pull out and don't forget to lube it for the seal to slide on.
Richard
PostPosted: Fri Apr 06, 2012 2:32 pm
Great Tip.
Thanks Richard.
PostPosted: Sat Apr 07, 2012 5:09 pm
We put them in by going around the pack with a thin feeler gauge to work the lip of the seal under.
If you can't easily push the piston down with your fingers you've got the lip rolled. :cry:
PostPosted: Sat Apr 07, 2012 7:03 pm
Thanks Dennis - That too is another way to go about this problem.
I was able to install it _ I just used My press and a large Ball joint socket to get it started - Problem was I couldnt get it started square just using my hands alone, then I would roll the seal.
