It is currently Tue Nov 10, 2026 3:52 pm
PostPosted: Mon Apr 16, 2012 10:09 pm
The fuel gauge on my 66 dart reads 3/4 full, when its full. Then it speeds down to the low fuel zone ( 1/3 tank ), and very gradually goes down from there throughout the week.
I knew about the problem, but it was not on my high priority list. Now its just making me mad looking at it and wondering how much is in there. The previous owner said it was looked at by a mechanic, and was told it would take ten minutes to adjust. I looked in the service manual but didnt see anything on adjusting the gauge.
Any help would be great! Thanks
1966 Dart Wagon /6 225 AT
PostPosted: Tue Apr 17, 2012 12:16 am
There is no "adjustment" to be made. Replace the fuel gauge sender. Chrysler P/N 4051 004, try www.chryslerpartsdirect.com .
If it doesn't come with a new fuel strainer, use GM part number 5651 705.
Gasket: Chrysler P/N 6031 475
Sender grounding clip: Chrysler P/N 2258 862
PostPosted: Tue Apr 17, 2012 10:57 am
dan, will those part numbers work for a 70 valiant? i'm in the same predicament.
-thanks
about 2 mins after i posted the above question, i realized that the part number library is on the home page of this site. DUH :roll:
70 Plymouth Valiant 4dr
PostPosted: Tue Apr 17, 2012 11:13 am
Yup, same part numbers.
PostPosted: Thu Apr 19, 2012 9:53 am
Don't overlook the possibility of a leaky float; I've had several corrode through and partially sink.
PostPosted: Thu Apr 19, 2012 10:29 am
Look at the whole set of symptoms, though. Partially-sunk float will prevent a "Full" reading, but will not cause the variance in gauge drop speed described by the OP.
PostPosted: Fri Apr 20, 2012 3:35 pm
You're right Dan, unless there are 2 leaks - a very small one on the upper side and a larger one on the lower side; that's what my brass float did.
