It is currently Wed May 20, 2026 5:43 pm
 Post subject: Tach
PostPosted: Mon Apr 30, 2012 4:59 am
Car Model: 1964 Dart 270
Is it possible to put a tach on my 64 Dart with a 225 slant six?
PostPosted: Mon Apr 30, 2012 7:57 am
Yes, almost any tach will work. Just have to figure out where to mount it. Steering column works pretty well on that car.
PostPosted: Mon Apr 30, 2012 9:43 am
And make sure the tach is set for 6 cyl i nstead of 8. (usually some sort of 3 position switch either on the back or under the outer shell). The Old Sun Super Tach and the Super Tach II had a little sweep type lever recessed in the rear and the middle setting is for 6 cyl.
MRO....
 Post subject: Tach
PostPosted: Mon Apr 30, 2012 10:22 am
Sounds good, been wanting a tach. Nothing fancy or too big just one to see the RPM's of the 225 as it roars along. Thanks for the info...........,.
PostPosted: Mon Apr 30, 2012 10:37 am
You can buy those tachs mentioned above at many parts stores. Advance is a big chain that sells them. I have the mini tach in 2 of my cars. One tach is 23 yrs old and works perfectly except for the light.
PostPosted: Mon Apr 30, 2012 11:31 am
Thanks Lou gonna check into one sometime this week...........
PostPosted: Mon Apr 30, 2012 7:07 pm
Car Model: 61 Valiant, 62 Lancer, 65 Val Ute, 66 Val convert
I used a tach from a 1962 Mexican Acapulco Valiant. It was set for a slant six. Pretty cool looking. Maybe a little big in size.
 Post subject: !
PostPosted: Tue May 01, 2012 7:58 pm
Picture please!
 Post subject: Mexican Tach
PostPosted: Wed May 02, 2012 6:18 am
Here is the picture of the mexican slant tach. I think it was also used in 63 and 64 mexican cars as well.
The font for the numbers matches my 1960 valiant gauges nicely.
 Post subject: Re: Mexican Tach
PostPosted: Wed May 02, 2012 7:00 am
Dang too bad VDO doesnt re-pop that item... Its too cool..
MRO....
PostPosted: Wed May 02, 2012 9:36 am
That is awesome, where did you find it?
PostPosted: Wed May 02, 2012 10:02 am
Nice looking tach. Are they hard to find?
