It is currently Sun Nov 22, 2026 11:28 am
PostPosted: Tue May 08, 2012 5:22 pm
it was a hassle, but i finally got a gasket that may be worth using, this is my 4th attempt in getting a good gasket.
first i tried purchasing an aussie, but it came broken in half.
2nd i tried to order a remflex, it came in broken on the end
3rd they sent me a 3inch 2bolt flange gasket as a replacement.....
4th this one seems doable but ill let you experts who have used these quite a bit decide.
it seems fairly scratched up, like it was rolling around with a tiny pebble underneath it. i know this thing does seal up to 1/16 inch of imperfection, but i just want to see if you guys have used remflex gaskets in similar condition.
 Post subject: Yep...
PostPosted: Tue May 08, 2012 6:25 pm
I have reused remflex gaskets that looked like that, should be OK.
PostPosted: Wed May 09, 2012 7:47 am
Reused? Thought these aren't reuseable
PostPosted: Wed May 09, 2012 10:36 am
I have used ones that were folded, and they worked.That scratched one looks fine.If you call remflex them selves, they will work with you.
Just my 2 cents.
Wife's: 64 Valiant
 Post subject: Lol...
PostPosted: Wed May 09, 2012 4:35 pm
:lol:
If you spray the manifold sides with PAM and use the advised torque, you can do a manifold swap as long as the PAm worked and the coating didn't self destruct they are good for one more manifold install and retorque at 15 lbs... I only get 2 installs then it's toast.
PostPosted: Wed May 09, 2012 5:36 pm
makes sence, cool man, will keep that in mind
