It is currently Sun Jun 14, 2026 1:03 am
 Post subject: od transmision.
PostPosted: Sun May 13, 2012 6:14 pm
Car Model: 1982 D150
Hi, today I found and bought an over drive transmission for a slant six.
I got it out of a 1983 dodge van (I think it said RAM, cannot remember)
I plan to install it into my 1982 D150. (currently has a NP435).
I am thinking its a 8330d.
Is this a good idea? I am looking for better high-way milage. Will i sacriffisacrificeh?
Please comment.
Also, is there anything I should know before making the swap, or will it bold right on?
Thanks again for all your help.
Slant power!!!
At least I try...
PostPosted: Sun May 13, 2012 6:20 pm
I was trying to say sacrifice too much!
Slant power!!!
At least I try...
PostPosted: Sun May 13, 2012 6:24 pm
hope you got the bell housing also ///if trans is OD one shift lever will be upside down compared to other 2....and front bearing is larger , as is hole in bell
PostPosted: Sun May 13, 2012 6:38 pm
Yeah you will need bellhouseing (as stated above) shifter and linkage for the OD tranny its side shift and 435 is toploader.
http://www.motivegear.com/tech_info/tra ... guide.html
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Sun May 13, 2012 6:46 pm
I was smart enough to get everything except for the engine. Bell, z-bar, clutch, flywheel, fork, everything!! If it was attached to the trany, I brought it with me. I even brought the broken and bent-up drive shaft.
Slant power!!!
At least I try...
