It is currently Mon Jun 15, 2026 10:37 am
Post new topic  Reply to topic  [ 41 posts ]  Go to page 1 2 3 Next
 Post subject: Roller Rockers
PostPosted: Thu May 03, 2012 2:42 am
Just thought I'd let you all know that T&D still make roller rockers even though they dont list them. Price unknown :roll:
Just thought I'd mention it as I've read some bad stuff about the RAS ones and I've been making some enquiries for a set.
Cheers
John
69 Valiant VF Hardtop
PostPosted: Thu May 03, 2012 8:38 am
http://slantsix.org/forum/viewtopic.php ... t+d#265375
PostPosted: Sat May 05, 2012 7:15 pm
American made?
PostPosted: Sat May 05, 2012 10:04 pm
Nope. Nevada. :lol: I think they are in Tristan's backyard.
PostPosted: Sat May 05, 2012 11:36 pm
I can be there in twenty five minutes. Not in my back yard but just a valley away! Nevada is preaty big! The KB silvolite plant is out there and earson cams used to be located near both of them.
TF
Even in moderation i am excessive!
PostPosted: Sat May 05, 2012 11:47 pm
Car Model: 64 Valiant
T&D makes good stuff, even though its pricey, you do get what you pay for.
PostPosted: Tue May 08, 2012 9:01 am
775-884-2292
just got off phone with them
$678 set PN. 8075
any ratio you want suggested 1.6
send your shaft they make them to your stuff.
4 weeks turn around
nice peeps on phone.
slant six's RULE!
http://www.usajon.com
PostPosted: Wed May 16, 2012 7:16 am
Car Model: 1964 Plymouth Valiant 225, 1977 Dodge D100 225
Cool! I'll have to make note of this. Would the 1.6 be good for an Erson 280/270 cam?
Chuck and the Flying Valiant
PostPosted: Wed May 16, 2012 2:47 pm
Buy the right camshaft to start with and you won't need $700 of rockers. :shock:
PostPosted: Wed May 16, 2012 4:27 pm
So...I didn't buy the right cam or I don't need new rockers?
Your sarcasm is hard to decipher.
PostPosted: Wed May 16, 2012 6:44 pm
I was not being sarcastic.
When building an engine you buy a cam that fits what you want to do. You do not just buy any cam and then add bandaids to make it work.
I can pretty much guarantee that after paying $700 or so for a set of 1.6 rockers you will not see much if any difference in your performance.
Trust me, I spent $425 on a set of RAS 1.6 rockers and have switched them at the track and seen no difference. :cry:
PostPosted: Wed May 16, 2012 6:52 pm
armyofchuckness
I think the question is,, why do you think you need roller 1:6 rockers?
some things to consider
1)if you want more lift,, just spec a cam with more lift and use the stock 1:5 lifters
2) if you think you need rollers, consider that the stock shaft mounted slant six rocker is well designed and is actually very stable,, the GM crowd with the bucket and ball rockers, do go to rollers because their stock rocker is not stable.
the thought is ,, unless you are building a very high end motor, you may be able to get a bigger bang for your buck by not going with rollers.
PostPosted: Wed May 16, 2012 7:43 pm
I'm only going to 1.6 rollers as I'm building a 4/71 supercharged slant six with long rod conversion, fully prepped race head and a custom Aussie Camtech cam. Even then it maybe overkill but I've got the bucks so why not :lol:
PostPosted: Wed May 16, 2012 7:53 pm
Sorry about the double posting - bloody smartphone :roll:
PostPosted: Wed May 16, 2012 7:58 pm
Fair enough. In my defense, I bought the cam I have after careful consideration of my goals and discussing them with several experienced Slant 6 builders. I've heard about roller rockers before, and just learned that they're readily available again. With all the buzz I'd heard in the past, I was curious and wanted to know if they'd be good for the cam. I'm not looking for band aids so much as advice on complimentary parts. I'm sorry if I took your comment differently than you intended. Im trying to do things right the first time and sometimes I ask stupid noob questions just to make sure I'm not missing out on something important.
