It is currently Thu Jun 25, 2026 3:03 am
PostPosted: Mon May 21, 2012 11:23 am
so Im looking @ a 1967 Dart no vin on the driver's door jam
car is tagged driven
is the a vin anywhere else on this car that i can verify with the title?
slant six's RULE!
http://www.usajon.com
PostPosted: Mon May 21, 2012 11:50 am
Radiator support MAYBE??? Not for sure, but it will have another actually stamped in it somewhere... I am assuming you have your doubts about the actually VIN plate for wanting to verify?
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Mon May 21, 2012 12:26 pm
it's a pricey car
and in Maryland they will impond without a vin
you can get a reasement title but the hidden vin must match the title
or they keep the vehicle as altered aka issues
slant six's RULE!
PostPosted: Mon May 21, 2012 7:29 pm
Driver's door jamb is one.
Some have a sticker on the driver's door edge.
Fender Tag.
Last 6 of VIN on top of Radiator mount.
Same Last 6 can be found on certain years on the
crossmember rail under the carpet under the backseat.
PostPosted: Mon May 28, 2012 3:52 pm
When you open the door, you should see it by the door hinges between the door and fender.
