It is currently Sat Oct 10, 2026 1:41 am
PostPosted: Mon May 21, 2012 8:51 pm
so i finally got around to getting my exhaust manifold blasted, and painted up, ready for a mockup. i got my self the remflex setup, both heat riser, and manifold to head.
anyways i started mocking up the 2 manifolds as per the article. attached the 2 manifolds with the hotbox gasket, with 3 bolts hand tight. then layed it down on the head, and started from the center out, just hardly snug at all. then went back to the 3 manifold/manifold bolts, and torqued them down to 22ftlbs. as the article states. i slowly torqued them, from 15, to 18, to 20, then 22. so i didnt tight one side too much.
then i noticed that the ears of the gasket split, now im not sure if this is normal for this style of gasket (i never used a graphite gasket before), and is common, and people had no issues of running it as is, or should I tear it all back apart, and put a new gasket in place... but im sure it would just happen again. input?? thank you friends
manifold is painted with a high temp cast iron color paint, i think it looks great.
 Post subject: I would...
PostPosted: Mon May 21, 2012 9:28 pm
Leave it and run it. The important part is the gasket at the hotbox flanges, not the ears.
PostPosted: Mon May 21, 2012 9:59 pm
i was just thinking maybe somehow the gasket would start to split all the way around, then burn out.. but i guess its good to go.
now i just need to find a place to surface the manifolds flat. that seems to be the hard part.
Yup, it's normal and fine.
PostPosted: Tue May 22, 2012 12:58 pm
okay, i got another question, instead of starting new thread ill use this.
with out any gasket at all, the largest gap i have is .016, between manifold and head. since im using the remflex gasket, which states it will fix 1/16" of gap, im just not sure if the 10ftlb torque is enough to crush it, to take up that gap.
ive been trying to find a shop that will surface it, preferably a belt sander since it would be the quickest, and cheapest route, but i only found 2 shops, one with a blanchard grinder, and one with a mill, who is willing to do it, for more money then its worth, especially if the stock manifold eventually cracks.
my buddy has just got a mill, but its not ready, needs to be wired into his phase converter, and he needs collets. id just like to get this done quicker, and if i can get away with no surface that would be great
anyone check the gap of warped manifolds, and ran a remflex with no issues?
PostPosted: Tue May 22, 2012 2:29 pm
Put some wet/dry sandpaper on a flat surface and do it yourself............(an actual use for WD40 tooo)
PostPosted: Mon May 28, 2012 11:50 pm
got it surfaced on a blanchard grinder, found a shop who would do it for $50. took them about 15 mins.... a bit much but guess they gotta pay for the machine some how ;-)
PostPosted: Mon Jul 30, 2012 9:39 am
I used the remflex box gasket successfully, and also installed a thin sheet of stainess steel that covered the entire open area between the manifolds.
I wanted to reduce the intake manifold's direct exposure to the exhast blast. I also wired the butterfly valve wide open to further deflect the hot gases.
I still get fast warm ups(I have a manual choke), but my carb doesn't get nearly as hot and boil the fuel in the bowl like it used to without the sheet metal blocking plate.
1968 Plymouth Barracuda Convertible Super six
Users browsing this forum: No registered users and 15 guests
