It is currently Tue Nov 17, 2026 12:41 pm
 Post subject: Just Grumbling....
PostPosted: Wed May 23, 2012 5:26 am
Contributor
My Valiant recently began temporarily losing ignition power while driving. It doesn't just miss, it dies. It only lasts for a few seconds, so I suspected a bad firewall connection. Since all other electrical functions are fine, I concentrated on wiring in the ignition circuits. Cleaning bulkhead connector terminals didn't help, so I cleaned and tightened every connection that was ignition related, and I still have the problem.
The last time it failed, I didn't get the car in neutral as fast as I should have, and enough unburned fuel collected in the exhaust to blow the back off the muffler when it fired again. I really hate when that happens...
FWIW, I also have a NOS ignition switch that was installed a few months ago. The MP electronic ignition is also relatively new, and the orange box is from the days when they were US made. Even so, I'm going to install a new stock box to see if that does the trick. Just wish I could find one made in North America.
I love old cars, but sometimes the problems can be a real pain to track down...especially the intermittent ones.
 Post subject: Re: Just Grumbling....
PostPosted: Wed May 23, 2012 10:12 am
…not really suitable for street use, unless you (thoroughly) rework the distributor's mechanical advance.
the orange box
…has been not a very good unit since before they were sourced in China.
Can get from Old Car Parts Northwest.
PostPosted: Wed May 23, 2012 12:05 pm
Contributor
The distributor has stock springs and vacuum can from...I think it was a '79 slant. I reworked it a couple of years before I bought my car, so it sat on the shelf for quite awhile. I got the MP kit in a closeout deal for less than the cost of a new stock distributor and couldn't pass it up. It runs perfectly...when it's getting spark.
Thanks for the link to the good parts source!
PostPosted: Fri May 25, 2012 12:39 pm
Divide & conquer- don't guess at the problem, diagnose it. Get about 15 feet of small gauge wire. Connect one end to the ignition coil +. Run the wire out the back edge of the hood & into the passenger area. Connect it to the tip of a 12V test light & (solidly) ground the other test light lead/clip. The light should glow - dimly- while the eng runs. If the light goes out when the eng "cuts" out, (ie, you're losing coil power) then move the wire closer to the ignition switch & retest until you find the fault . If the light stays on, (ie, you're losing coil ground) then you need to diagnose the ignition system.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri May 25, 2012 2:33 pm
Contributor
If it failed with any degree of regularity, that would be a reasonable idea, but oftentimes it goes for days without failing. For now, it only happens often enough to be annoying.
PostPosted: Sat May 26, 2012 2:58 pm
Intermittents are a pain in any generation of vehicle.
Your coil can also cause this problem.
PostPosted: Mon Aug 27, 2012 10:44 am
Bulkhead connectors are always my first spot to check.
PostPosted: Tue Aug 28, 2012 4:33 am
Contributor
FWIW, I replaced the ignition module with a stock unit that is USA made. Since the coil was the original, or at least it was on the car when I bought it ten years ago, I changed it also. No more intermittent cutoff.
PostPosted: Tue Aug 28, 2012 11:25 am
If the problem comes back, also check the ignition switch to harness connector; I've seen them overheat and make a poor connection sometimes.
PostPosted: Tue Aug 28, 2012 2:02 pm
Get rid of that Orange Box, those things suck. The one I had lasted three weeks and died.
82 D150-225/727
02 Dakota-3.9/5 speed
