It is currently Sat Jun 13, 2026 5:25 pm
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3
PostPosted: Wed Oct 26, 2011 9:52 pm
Almost forgot, I installed an AEM digital water temp gauge tonight. works great. Got it from a guy on another dodge forum fo $70 shipped which was a score since it was $150 new from summit.
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Thu Oct 27, 2011 9:11 am
That's neat, your truck came with the little storage box above the A/C controls. Mine just has one of those big plastic covers with the fake louvers molded into it.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Oct 28, 2011 3:58 pm
thanks. Thats actually the dash from a Ram with the Royal trim package, which is why it has the fake wood grain. but its not big enough to put anything else in.
PostPosted: Fri Oct 28, 2011 5:42 pm
Ross
nice truck and you are really making it yours, it is interesting to see the progress
did yours come with a front sway bar? My 83 did not, but I found one at the pull a part,, have not put it on yet, but looks to be a straight bolt on.
I have also found a rear sway bar,, believe it is an after market piece as its the only one I have seen.
regards
DT
PostPosted: Fri Oct 28, 2011 8:03 pm
Mine didn't come with a swaybar either. Hitting the offramp usually involves bracing my leg against the door panel so I don't get smushed up against the door.
82 D150-225/727
PostPosted: Fri Oct 28, 2011 10:42 pm
Yeah mine has a sway bar. It corners fairly good for a big old truck.
PostPosted: Mon Oct 31, 2011 1:31 pm
Now that's a lot of work gone into it.
Sweet looking truck. 8)
DRIVE IT,DON'T HIDE IT
PostPosted: Tue Nov 01, 2011 8:21 pm
Thanks!
UPDATE:
Got a dual electric fan set up from a 99 caravan. Had to make my own brackets for it.
PostPosted: Tue May 15, 2012 10:54 pm
Wow its been a long time since ive updated this thread. No i didnt die, just havent posted in awhile but have done a lot to my truck since i last posted. hmm lets go back a bit.
After i got my fans on i realized i needed something better to mount my switches on, so i made a center console. Not the best but i used what i had at the time.
Switches are; Top left: Coil. Top middle: cooling fans. Top right: air compressor for onboard air system. Bottom left: under dash lights to light floor. Bottom middle: 12 volt outlet. Bottom right: aftermarket gauges and heater.
Bedlined floor and back wall
led strips in gauge cluster
wheeling in the snow in mt hood, yes wheeling my 2wd, it does amazing in the snow... with 600lbs of snow in the bed and aird down tires :lol:
Trying my buddies 32's on and jack the truck up to about where it will be when im done. Yes im lifting my 2wd, its called a prerunner and i like it.
relocated my horns under my new diamond plate box
took the vc off to clean and paint it and replace the gasket. id say that doesnt look too bad for 196k miles 8)
And my brush gaurd with my docked bumper. when i get more tube i will add to the gaurd and make skid plates and ditch the bumper.
Ive been thinking two tone with black and sublime green
PostPosted: Sun May 20, 2012 1:11 pm
Blaster 2 coil
Painted vc, it was dusty when i took the pic.
PostPosted: Sun May 20, 2012 1:25 pm
Looking good. You need some furry leopard print material to cover that fiberglass console, though.
PostPosted: Mon May 21, 2012 12:00 am
Its not fiberglass. The sides are pieces of 2x4 screwed together and the top is plywood all of which I had lying around.
PostPosted: Wed May 23, 2012 6:56 am
What's the compressor for? Just incase, or do you have airbags? or something else...?
Looking good!
PostPosted: Wed May 23, 2012 8:57 am
On board air system. I have air tools in case something happens when im out on trails with friends and for my air horns. Those horns take lots of air to sound.
PostPosted: Sun Jul 28, 2013 8:23 am
Its for SALE! I post an ad in the for sale section.
