It is currently Wed Jul 15, 2026 9:36 pm
PostPosted: Tue May 22, 2012 11:46 am
Hello folks, Would any of you recommend trying pinion angle shims on ruster as a way to improve bite or 60' times?? I have no Caltracks or four link etc.. just stock type Leafs..
Thoughts?
I have pinion angle shims in 2*, 4*, 6*..
Currently running with no snubber and Clamped front segment.
PostPosted: Tue May 22, 2012 11:58 am
whats your angle now?I angle cut my lowering blocks,think I am about 4 down,cant remember for sure.I dont use a snubber either,,,worn out leaf springs with one leaf added on top of pack upside down from the axel forward,not clamped.Guzzi Mark
PostPosted: Tue May 22, 2012 12:26 pm
pinion snubbers that adj
http://motors.shop.ebay.com/i.html?_nkw ... 506.c0.m19
slant six's RULE!
http://www.usajon.com
PostPosted: Tue May 22, 2012 1:07 pm
When I checked my angle after the driveshaft explosion it was 1* down..
Just trying some things.. or at least bench racing about them..
car wont go faster if I dont try out new ideas (or at least untried ideas) on ruster.
PostPosted: Tue May 22, 2012 2:20 pm
2 degrees down from what the transmission angle is.
PostPosted: Tue May 22, 2012 4:42 pm
More than 2 on a race car.
PostPosted: Tue May 22, 2012 6:17 pm
Find the angle on your trans yoke and put it 3-4 down from that.
PostPosted: Wed May 23, 2012 10:28 am
Cool . thanks for all the replys guys..
Once I get the new Alt Mounted and working on the car I am going to try some of the shims and I also have one of the spring packs modified like Guzzi Mark Suggests ready to bolt in..
Just gotta get me time to do all this junk!
PostPosted: Wed May 23, 2012 11:56 am
You da man, Greg. You'll go 11s with your other converter, and I'm sure you'll keep walking it down. Records in your future?
PostPosted: Wed May 23, 2012 4:42 pm
I gotta keep trying stuff.
I dunno.. I have a long waay to go before records.. Maybe I'll stick with 45's and some LP's :-)
