It is currently Sun Nov 15, 2026 12:47 pm
 Post subject: Wiring
PostPosted: Fri Jun 08, 2012 7:24 pm
Need some input here..
I have installed a GM/DENSO style 50 AMP Race ALT on the 67 Dart, it is a one - wire... Do I wire it to the Starter directly by way of a toggle switch? Or do I wire it to the Master Cut off switch? Also what gauge wire should I use???
Thanks....
BIG T
1967 Dart "Six Shooter"
Girlfriend Rhonda... 66 Valiant
Image[/URL]
PostPosted: Sat Jun 09, 2012 4:32 am
If you have a trunk mounted battery and a rear cutoff switch, the alt. wire should connect to the pos battery terminal, or the battery side of the cutoff switch. I would use a minimum of 8 gauge.
PostPosted: Sat Jun 09, 2012 6:42 am
Thanks Charlie..
Yes it is trunk mounted ... I wasn't sure what gauge wire I should use...Thank You...
Will give me something to do today while the girlfriend goes for her sat ride on her Sportster
BIG T
Image[/URL]
