It is currently Sun Nov 15, 2026 3:02 pm
PostPosted: Thu Jun 07, 2012 7:15 pm
Ok, the fuel gauge and sender in my 1952 Chrysler are not working. The gauge will be fixed when I rewire the car next month, but I took the sender out and it is pretty corroded.
For now I do have a fuel gauge, Ford/Chrysler type, 81449.
I would like to get an universal sender to work with it, but I do not know the ohm range.
Also is my aftermarket gauge the same ohm range as my factory one or will I need to change senders again?
Any info would really help!
Thank you.
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
PostPosted: Thu Jun 07, 2012 8:36 pm
Oh, also, is it possible to mount one of those universal senders to my original tank?
Tony
1964 1/2 Barracuda
Slant Six 225
(my dream car)
PostPosted: Sat Jun 09, 2012 7:00 am
If the gauge IS in fact a ford/chrysler compatible gauge the factory ohm range is 10-73 ohms.(not knowing what brand of gauge you have) Empty being 73ohms... (not exact but within a small tolerance) The universal sender can be used if thats the range it operates in...
That is an unknown, due to the fact the original gauge is/was in a 6volt system..
Thank you.
Hope this helps...
MRO....
Cheap, Fast, Reliable.... Pick 2...
