It is currently Sat May 30, 2026 11:07 am
PostPosted: Sat Jun 09, 2012 10:35 am
With the info I got its a 1966 225 RG . I here you guys
talking about getting the older slant sixes .And what does the
RG indicate ?
Since I bought my 63 my guitar
has taken the back seat.
PostPosted: Sat Jun 09, 2012 11:02 am
The slant-6 engine was internally known at Chrysler as the "G engine". There were two block heights: the "LG" (Low G) was used for the 170 cubic inch engine. The "RG" (Raised G) was used for the 225 and 198 cubic inch engines.
Whether this particular engine is worth rebuilding depends on its basic condition and what kind of vehicle you intend to run it in. What is your overall level of experience with vehicles and engines in general?
PostPosted: Sat Jun 09, 2012 11:14 am
Its going into a 63 Polara and from a scale of 1-10 I would have to
a 5 , I can change parts diagnose certain things but as far as rebuilding thats
something else. The engine still runs strong .My intention on buying this car was to put a 383 in it until I got the slant six bug .
PostPosted: Mon Jun 11, 2012 9:20 am
What is the problem (s) with the current engine?
Rod knock, smoking & oil consumption or??
 Post subject: Is it worthy
PostPosted: Mon Jun 11, 2012 12:08 pm
She runs good , but when I take on long jaunts she still runs good until
I come to an idle and sounds like shes out of tune or running hot.I
changed waterpump , radiator hoses , thermostat , even fuel pump
thinking maybe vapor lock. Someone did mention about checking
valve lash .
PostPosted: Mon Jun 11, 2012 12:10 pm
Forgot to mention the temp gauge dont work, any info would be
helpful. Thanks John
PostPosted: Mon Jun 11, 2012 1:31 pm
If your only issue is rough running when hot, I would start with much smaller and simpler solutions before I decided the motor needed a rebuild. Start by adjusting the valves.
PostPosted: Mon Jun 11, 2012 3:10 pm
Thanks Reed , was also told to check for valve lash . Makes sense to me
and the only thing I didn't replace was the radiator. Is this a common occurence in these engines as they get old or just in general with engines
period.
PostPosted: Mon Jun 11, 2012 7:39 pm
Step one will be to get the three books described in this thread as quickly as you can, and read them.
Tune-up parts and technique suggestions in this thread.
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
And yes, you'll want to do a valve adjustment.
PostPosted: Tue Jun 12, 2012 9:50 am
Thanks everybody for all the info , and have found out the hard way
of being very careful of what you say in here , I have some thick skin
but steppin in the !^&% aint to good for the shoes , going to upgrade
and put my wadders on .And whats going on with these flags last time I
checked was running a 1bbl not a 2 and super six ?
PostPosted: Tue Jun 12, 2012 10:17 am
Just testing to see if I have that silly 1 bbl back on my profile
PostPosted: Tue Jun 12, 2012 10:48 am
1BBL, 2BBL are based on posting counts... the more you post the better you "run". :wink: :lol:
Keep an open mind and "thick skin"... you need that when running a SL6, especially in a full size vehicle.
PostPosted: Tue Jun 12, 2012 1:48 pm
Hey... based on that, by christmas I will be turbo charged :P
Thanks Doc
Users browsing this forum: Bing [Bot], Pilot01 and 6 guests
