It is currently Thu Nov 26, 2026 8:15 pm
 Post subject: rpm flutter
PostPosted: Mon Jun 11, 2012 3:51 pm
while racing after i do my burnout and pull up to the line when i bring the rpm up to 2700 with the clutch in to get ready to launch it fluctuates 500 rpm.it revs up fine up to 2300 and will hold a steady rpm but once i go over that it starts. its almost like its bouncing off of a limiter. its not really a problem but im curious as to why it does it.
PostPosted: Mon Jun 11, 2012 3:53 pm
225 slant stock internals and head with a 4bbl 390 holley and shorty headers running open.
car runs beautifully under normal driving conditions it only happens when im getting ready to launch
PostPosted: Mon Jun 11, 2012 7:30 pm
Maybe, a possible rich condition. Is this a vacuum secondary carb? What is the vacuum signal at this rpm?
PostPosted: Mon Jun 11, 2012 7:35 pm
Site Admin
The pump will "wiggle" causing the accelerator pump to dribble fuel from the shooter. Try moving to screw hole number 2 on the pump cam. Make sure to recheck the pump adjustment after changing the pump cam position. A small amount of movement on the leading edge of the pump cam can cause this.
Just a possibility...
2¢
CJ
 Post subject: x2
PostPosted: Mon Jun 11, 2012 8:35 pm
What is your vacc. reading at this level?
Pump dribbling can be a cause (check your pump cam clearance), if the vacc reading is still high you might be pulling fuel out of the shooters as well (which may require the addition of a needle weight in the pump bore- something standard on the 600 dfm Holleys, but I've never seen them stock in the 8007's).
I would also take a serious look at your timing as well, if you are running a stock points distributor that has not been degunked or a spring is broke your timing could bounce varying rpm.
Users browsing this forum: Ahrefs [Bot] and 27 guests
