It is currently Sun Jun 21, 2026 2:36 pm
PostPosted: Tue Jun 12, 2012 8:45 pm
Installed the A/C system with a friend during this last weekend... here are some pictures:
and here are some more pics, (engine bay)
I also manage to remove the distrubutor which has been giving me trouble lately
What do you think?
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Tue Jun 12, 2012 11:05 pm
Interesting low-mount compressor bracket. Did you make it, or buy it? If bought, where?
I "think" your distributor is a Prestolite IBR-4203G. What would you like to know about it?
PostPosted: Wed Jun 13, 2012 6:25 pm
The bracket was locally fabricated and looks like this:
Thats the old solex carb by the way.
As for the distributor, yes you are correct its Prestolite.
I was having trouble with the ignition timing going crazy, like advancing by itself once I drove more than 15-20 miles and will start pinking badly. When I use the timing light to time it, the "flash" moves all over the place too, so I cant time it properly.
The timing chain is new, the harmonic damper is new, belt is fairly new. Plug cables is less than 6 mths old.
I think the plate at the bottom of the distributor is "moving" or one of the spring inside the dizzy is missing/broken... which is why I took the dizzy out.
Syed
PostPosted: Wed Jun 13, 2012 6:33 pm
Good opportunity to pick up a new electronic dizzy from Old Car Parts Northwest Image
