It is currently Thu Jul 16, 2026 3:42 am
Post new topic  Reply to topic  [ 72 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Sun Jun 17, 2012 7:33 pm
Online
Okay So If I Installed a Two Step then I guess I am no longer considered a foot breaker???
Probably Jumping me into super Pro type classes?
Does the Same hold true for trans brakes?
Just curious..
PostPosted: Sun Jun 17, 2012 8:38 pm
A 2 step by itself is grey area Greg. Some tracks allow them in Street/Sportsman/No E, some don't.
A brake will most certainly move you into Pro, but they are allowed in most No/E classes.
PostPosted: Sun Jun 17, 2012 10:10 pm
Slantzilla wrote:
I can tell you from personal experience that a 2 stepp will hold a higher stall on the starting line than foot braking alone.
I kind of mis spoke when I told Greg a 2 step never made any difference. It will allow a higher stall than foot brake alone, but my reaction times never changed much.
I can pretty much guarantee that foot braking will not hold against much boost.
[/quote]
RE: "I can tell you from personal experience that a 2 step will hold a higher stall on the starting line than foot braking alone."
Wait a minute; I want to understand what you are saying here.
Do you mean to say that a car that is stalling with a 2-step at 3,800 rpm will not push hard enough against the brakes to move the car, but a car stalling at 3,800 rpm WITHOUT a 2-step will act differently and push through the brakes and move the car??? Even though they are both turning the same rpm...???
Tell me how the brakes know the difference. 3,800 rpm is 3,800 rpm, is 3,800 rpm as far as the brakes know. The same rpm of a converter run up against the brakes, will always generate the same output shaft torque... or, it couldn't be turning the converter 3,800 rpm. It would have to be turning slower to lessen the output shaft's available torque. Quantitatively speaking, torque multiplication (at stall) is directly tied to rpm.
But, that is not my concern. My concern is that a 2-step that works great on a normally-aspirated or supercharged car, might cripple a turbo car's ability to spool the turbo at stall. The turbo WILL react to the heat of combustion that expands the air to spool the turbo, in a somehat linear fashion. Kill some of that heat by disabling the spark in some cylinders and the available heat to expand the air that is necessary to spool the turbo will be lessened. I am apprehensive about what that could do to the way in which the turbo reacts to that stall-start.
I figure I need all the torque available, and floorboarding the accelerator at stall is the only way for me to get it. If that requires a trans-brake, (to hold the car still, at this full-throttle stall,) then I will just have to get one... no doubt about it.
In the meantime, I am going to attempt to maximize the rear braking ability by installing a master cylinder with significantly smaller-diameter primary cups, and try to find some rear drums that are larger-diameter and maybe, have wider shoes than these B-body brakes that are on the car. Might even find some wheel cylinders that are larger-diameter that will fit that bigger rear brake setup... I'm just going to do what I can...
I am only planning on running a 3.55:1 ring and pinion with a spool, but I do have the 2.74:1 planetary in the 904.
I may be involved in a futile attempt to generate enough holding-power on the starting line to enable full-throttle stall-starts, but I'm going to try, at least. I don't much care for trans-brakes because of how hard they are on the drive-train. I do have aftermarket (racing) axles and 7290 U-Joints, but there's always something... LOL!
Thanks for you interest and advice; I do appreciate the input!
Bill, in Conway, Arkansas
PostPosted: Sun Jun 17, 2012 10:40 pm
Car Model: 64 Valiant
Bill, when you start building boost on the converter with a turbo or supercharger, you will find that you can't put big enough brakes on a car to hold it back while just footbraking it, thats why things like transbrakes and 2-steps were invented. Your in the 21st century now, so embrace the technology that has been developed for you. Guys have been doing this for over 20 years with the Buick Grand Nationals, NMCA 5.0 Mustangs and others, there simply is no other way to achieve it. I think your trying to over-analyze the effects without first trying it out.
 Post subject: trans BREAKS...
PostPosted: Mon Jun 18, 2012 9:10 am
Well, I agree that I am probably going to end up with a trans-brake on this old car... I am, however, a poor boy though, and that's $550.00 that I'd rather not spend if I don't have to. But, I agree; it's probably inevitable. One thing; I will haave no use for a 2-step if I go with a trans-brake. Just put it on the floor and wait... LOL!
Does anyone with trans-brake experience have any reccomendations or advice relative to whose trans-brakes work well? Turbo Action, maybe???
I have no idea where to get a good one.
Thanks for any advice!!! I appreciate it.
Bill in Conway, Arkansas
PostPosted: Mon Jun 18, 2012 12:17 pm
How about this: 3800 rpms with no boost, 3800 rpms with 5# of boost and 3800 rpms at 10# of boost....still think the brakes are seeing the same 3800 rpms???
Nitrous cars are like old men on Viagra. Once the bottle is empty they are useless.
FJD
PostPosted: Mon Jun 18, 2012 3:16 pm
Bill, the whole idea of a 2 step is so you can leave at WOT, but hold the RPM at a set point. The 2 step drops random cylinders and keeps the engine from revving any higher.
At WOT with no limiter the motor is just going to try and keep revving up and will overpower the brakes.
Case in point, last year I had Mike Jeffrey's 3500 stall PTC converter in my red car. With no 2 step I could hold it on the line at about 2600 or so. With a 2 step I could hold it at 3400. 10" drum brakes all 4 corners, NA motor.
Yes, with a 2 step and turbo you will probably bang a couple times while the tree comes down. Watch video of the X275 cars and such. They really raise hell on the limiter. :lol:
PostPosted: Mon Jun 18, 2012 5:30 pm
Watch the big turbo guys. They actually want rich fuel mixture in the pipe between the head and turbo. They then have a couple of options some of which cause the banging on the starting line and yes they are doing that on purpose.
Retarding ignition
The throttle bypass/throttle solenoid system is combined with ignition retardation and slight fuel enrichment (mainly to provide cooling), typically ignition occurs at 35-45° ATDC. This late ignition causes very little expansion of the gas in the cylinder; hence the pressure and temperature will still be very high when the exhaust valve opens. At the same time, the amount of torque delivered to the crankshaft will be very small (just enough to keep the engine running). The higher exhaust pressure and temperature combined with the increased mass flow is enough to keep the turbocharger spinning at high speed thus reducing lag. When the throttle is opened up again the ignition and fuel injection goes back to normal operation. Since many engine components are exposed to very high temperatures during ALS operation and also high pressure pulses, this kind of system is very hard on the engine and turbocharger. For the latter not only the high temperatures are a problem but also the uncontrolled turbo speeds which can quickly destroy the turbocharger. In most applications the ALS is automatically shut down when the coolant reaches a temperature of 110-115°C to prevent overheating.
Inlet bypass
An ALS system working with a bypass valve which feeds air directly to the exhaust system can be made more refined than the system described above. Some of the earliest systems of this type were used by Ferrari in F1. Another well-known application of this type of anti-lag system was in the WRC version of the 1995 Mitsubishi Lancer Evolution III and Toyota Celica GT-Four (ST-205). Brass tubes fed air from the turbocharger's Compressor Bypass Valve (CBV) to each of the exhaust manifold tracts, in order to provide the necessary air for the combustion of the fuel. The system was controlled by two pressure valves, operated by the ECU. Besides the racing version, the hardware of the anti-lag system was also installed in the 2500 "Group A homologation base WRC method car" street legal Celica GT-Fours. However, in these cars the system was disabled and inactive. The tubes and valves were only present for homologation reasons. On the Mitsubishi Evolution later series (evo 4-9, JDM models only) the SAS (Secondary Air System) can be activated to provide Antilag.
Turbo and intercooler bypass (D-valve)
A method by which a large zero cracking pressure one-way check valve is inserted just prior to the throttle body, enabling air to bypass the turbo, intercooler, and piping during periods where there is negative air pressure at the throttle body inlet. This results in more air combusting, which means more air driving the turbine side of the turbo. As soon as positive pressure is reached in the intercooler hosing, the valve closes.
Sometimes referred to as the Dan Culkin valve.
When used in a MAF configuration, the D-valve should draw air through the MAF to maintain proper A/F ratios. This is not necessary in a speed-density configuration.
Two Step Anti-lag/launch control
A method of anti-lag developed along the same technique previously mentioned, but designed only to allow reduction of turbo lag when a car is initially pulling away from a standing start. These systems can be integrated into the engine management or existing anti-lag system, or can be fitted as a standalone unit. The basic method of operation is to artificially lower the engine rev limiter to hold the engine at a speed where the turbo can produce usable boost, by altering the ignition. Because the ignition is alternately cut or retarded, there is similar noise and misfires associated with other anti-lag systems. Systems for Two Step launch designed to be fitted in addition to the existing engine management work by interrupting the crank position sensor signal, so that the engine develops a controlled misfire at a pre-determined RPM. The basic premise of the launch control system is to build positive boost pressure from a static engine, releasing full or increased power to the wheels when the car starts to move off. It is most commonly used in turbo-charged drag racing, primarily in the US and Japan, although most WRC cars utilise launch control to ensure that the cars can get off the line much more quickly.
Hope that helps.
FJD
PostPosted: Mon Jun 18, 2012 10:02 pm
Thanks for all the good info! I am time-limited right now, so can't respond at this time, but will get back to you all later tonight, late.
Gotta run for now.
Thanks again.
Bill
PostPosted: Mon Jun 18, 2012 10:58 pm
That would take 3 different torque converters, if they were all full-throttle stalls.
Here's why:
It takes a certain amount of torque to create a stall speed of any given RPM (say, 3,800 RPM.)
Let's say, it takes 400-foot-pounds of torque to spin a given converter 3,800 RPM against the brakes (which, for the sake of this discussion, are holding the wheels stationary.)
If the torque being applied to the converter is then increased, the stall speed will increase along with it. It's being turned with more force, so it will stall faster (at a higher RPM.)
Stall speed is the balance of applied torque (from the motor) versus the converter's ability to absorb that torque and not let the motor spin any faster.
I can't envision any other scenario.
If you agree with that, then you'll agree that a converter that is allowing 3,800 RPM of "slip" (the rotational difference between the crank-driven element and the driving [stationary] element,) is doing so because of the AMOUNT of torque being applied to it. It comes up to a "wall."
Nothing else.
If you decrease the amount of torque to, say, 200 foot-pounds, the stall speed of that particular converter will slow down (using no boost at all, for instance,) probably to around 2,500 rpm (just a guess.)
Now, If you increase the boost from zero to 5 pounds, the stall speed will increase to maybe 3,200 RPM, due to the force afforded by the additional torque coming from the 5 pounds of boost.
Boost it on up to 10 pounds, and you might get 3,600 rpm. stall speed, and 350 foot pounds of torque.
But, each increase in boost will cause an increase in torque (up tp a point.)
That's why you'd need 3 different torque converters to perform your experiment that asked about the brakes.
The same torque converter, however, will always require the same amount of torque to spin it any given RPM (in this case, 3,800) against a non-yielding brake. The torque conversion ratio will always be the same at any given RPM; it's in its DNA... in a case like this, it might be as high as 3:1. That too, is just a guess, but I believe that if it's spinning 3,800 RPM and the output shaft is not moving, then it took the same amount of torque to spin it that fast, regardless of boost, no boost, or any other flrxible paraameters.So, I believe the answer to your question of "still think the brakes are seeing the same 3800 rpms???" is yes, I do.
I can't see any way the brakes can know where the power came from, since it's always going to be the same amount of power (torque) in, and the same ampunt of power (torque) out of the converter, IF the rpm remains thee same.
Two-stepped or not, boosted or not, it's still going to take the same amount of torque to get that converter in question to stall 3,800 RPM.
The brakes "see" the result of this in terms of how much torque multiplication took place in the converter. It will always be the same amount at the same RPM.
If you think that all this, (or, any part of it) is not true, then please explain how the converter would stall at the same speed (3,800) with a different amount of available torque. As I understand it (and, I reiterate it,) stall speed is a function of the engine's delivered torque, applied to the converter, resulting in a stall speed that reflects the converter's ability to absorb that torque up to a certain RPM, and let the crank speed go no faster.
That's all just my opinion, though... nothing more.
Thanks for listening!
PostPosted: Mon Jun 18, 2012 11:14 pm
'Zilla,
Have you ever used a 2-step on a turbocharged car? Or, is all your experience with a normally-aspirated motor?
I think turbo vs. N/A is apples and oranges when it comes to 2-steps.
Could be wrong, but I'd like top see some positive results from some turbocharged drag cars with 2-steps before I spend my hard-earned cash to buy one; I don't have much (cash) left, after building this monstrosity... LOL!
PostPosted: Tue Jun 19, 2012 4:29 am
Bill, you can choose to believe what I (and others here) say or not, but I can guarantee that you will never hold a boosted car on the line at WOT without a limiter of some type.
To really do what you want to do you will need a 2 step and a brake. Even with a brake you will still need a 2 step or you will be forever frying parts.
I can understand that you don't want to spend money needlessly, but there are some places you just can't cut corners.
Speed costs money, how fast you wanna spend it.
And no, I have never personally owned a turbo car, but I have worked on a few of them in my 40 years of hanging out at drag strips.
PostPosted: Tue Jun 19, 2012 4:36 am
A car at 3800 rpm on a 2 step is more like a 3 or four cylinder, there for making less torque at a given rpm than a 6 cylinder.
Will
PostPosted: Tue Jun 19, 2012 9:46 am
Bill, here is what some of your Inline cousins are doing. Here is a personal best for just a fancy ole truck, if you ever see him at a race, don't think it is an easy target just because its an old truck with DOT tires also, you might get your feelings hurt :P . This one is 8.44@160 MPH http://www.youtube.com/watch?v=WjQ7PmXSKcw[url][/url
http://www.youtube.com/watch?v=gex-uUio8DcThis is a solo pass and you can hear him get on the low side chip after he rolls in and final stages. But, thats how its done.
PostPosted: Tue Jun 19, 2012 10:35 am
I can't and won't argue that point with you, because I believe you're probably right on that score. I will probably try SOMETHING, though, hard-headed (and, poor) as I am...
What I take issue with (and what neither you, nor anyone else has addresed,) is: that you don't seem to want to acknowledge that stall speed is just a balancing act betweeen available torque and the converter's ability to prevent the engine from stalling at a higher speed. That is a simple one-to-one relationship that results from converter design. Add more torque (more boost or a biggerr engine) and the stall-speed goes up; cut it, with a 2-step (or less boost or a smaller engine) and the stall-speed will go down.
Put another way, I think it takes the SAME amount of torque to generate any given stall-speed with any given converter, regardless of how the engine delivers it. That said, it follows, that the amount of torque coming out of the output shaft of that converter will reflect exactly what is coming INTO it... X foot pounds X the multiplication ratio.
So, why would it matter whether the engine was 2-stepped or not, if the stall-RPM is the same? It takes the same amount of torque to generate that stall speed, however you get it.
If that's true, then a situation wherein you have a given stall-speed (say, 3,000 RPM ,) will take a certain amount of braking to hold the car on the starting line, no matter how that stall speed was attained (2-step, or no 2-step) because it's going to be delivering the same amount of torque to the output shaft, either way... because there's the same amout going in; if it were less, the stall-speed would be less.
Where is the flawed logic in that argument?
I have watched 2-stepped cars for years and I know that 2-steps work very well in most cars. I am only skeptical about one's ability to work well in my particular application because of what I DON'T KNOW about how being on a two-step will affect exhaust gas temperatures going into the turbo impeller. They (those exhaust impellers) are totally dependent upon the expansion of air due to heat, for their spooling-time, and no heat is gong to be generated by mixture from cylinders that didn't fire because of the 2-step. I am apprehensive that I might be shooting myself in the foot by trying to use one (2-step.)
That is my only concern.
If I could 2-step this thing down to, say, 2,500 RPM and get away with it (not hurt turbo spool time) that would definitely be the way to go, I think.
Perhaps, if I could go ahead and two-step it and add a 75hp shot of nitrous for one second, just as the car came off the 2-step, it would spool the turbo quickly enough for the launch??? What do you think?
Well, by the time you started "hanging out at drag strips," in 1972 I had been a tech inspector at three different drag strips (Carlisle, Arkansas, Little Rock Drag Strip, and Des Moines Dragway in Iowa,) had built and raced two Gas Coupes ( a C/Gas Henry J with a Chevy V8, a '35 Pontiac coupe with a 345-inch Olds in B/Gas, and a '57 Chevy sedan delivery NHRA Stock Eliminator car (H/SA; 220hp/283c.i.d., Hydramatic car.)
Went to my first race in 1955 when I was seventeen, and the hook was set... deep. LOL!
Just tryin' for one last gasp with this turbo car and have been aware that the hairdryer cars always seem to have a problem with getting enough grunt for really good 60-foot times; whoever they outrun, they have to catch and pass them to do it.
I am trying hard to avoid that scenario.
If my 57 years of watching cars go down the strip has taught me anything at all, it's that there's always more than one way to "skin a cat."
I'm trying to look at all of them... that's all. :)
Thanks for your help!!! I appreciate it
Users browsing this forum: Amazon [Bot] and 1 guest
