It is currently Mon Nov 16, 2026 5:46 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Fri Jun 22, 2012 4:06 pm
The manual is correct. Counterclockwise increases the pressure.
Thanks for that Chuck.
I have some of those bad brain cells as well,normally on a Saturday morning,burp! :roll:
DRIVE IT,DON'T HIDE IT
 Post subject: Re: .
PostPosted: Fri Jun 22, 2012 4:15 pm
Further info in my "shift kit worth it for a daily driver" post I just bumped up from 1 1/2 years ago
Thanks,even more info.
Cheers,
PostPosted: Sun Jul 08, 2012 3:25 pm
Well i had my pan off on the weekend to check the rear band and put in my filter extension.I went to check my line pressure and there is no inner edge/cup to the adjusting nut
There is just a yellow spring,which i'm assuming is from the shift kit so i couldn't make any adjustment.
I don't know if the auto shop who recently put the kit in left it out by mistake or if the auto shop who rebuilt it about 3 years ago (before i had the car)left it out.
I do have a spare 904 in the shed that has the inner edge/cup on the adjusting nut.But this will be have to be a future job as the valve body will need a rebuild and i had to get the wagon back on the road.
