It is currently Sun Jun 07, 2026 3:45 am
 Post subject: Break in Lube
PostPosted: Sat Jun 23, 2012 5:28 pm
Here's an easy one. I'm making progress on getting the turbo wagon back together. The engine is on the stand, and I'm about to put the oil pan on. This block has been sitting without oil for 5 years, but it's clean inside. Is there anything I might want to baste it with while I have it on the stand. Some folks say lithium grease, some folks say lithium grease isn't oil soluble so I shouldn't do that. Anybody recommend anything, or should I just squirt it with motor oil and hand spin it till it gets up pressure?
Kip on Truckin'
1965 Valiant wagon Turbo slant (work in progress)
2000 Chevy 155" cargo van - The Abductor
1970 Newport convertible
1996 Buick Roadmaster Wagon
1966 CruiseAire motor home
1990 Toyota 1 ton box truck TURBO slant (scraped)
PostPosted: Sat Jun 23, 2012 10:03 pm
Gear oil, motor oil, or "assembly lube" would probably be best.
1985 Dodge D100 with Slant Six, Standard Cab Short Bed
PostPosted: Tue Jun 26, 2012 11:38 am
For brand new engines, I use my own blend of assembly lube, brad Penn and Lucas. It's very slick and very sticky. It will never run off while sitting for years, I've checked. And I also use comp cams break in zinc additive for lifter/cam
 Post subject: Isky
PostPosted: Tue Jun 26, 2012 6:27 pm
Isky makes an assembly compound that incorporates moly in it called "Rev Lube". It's good stuff.
PostPosted: Tue Jun 26, 2012 8:26 pm
Forgot to mention I use arp grease for cam and lifters, and I make sure they got a lot on them. It's just moly grease, good for cam break in
Users browsing this forum: Ahrefs [Bot] and 4 guests
